95 taco 4x4 reg cab rear drive shaft
Old 04-13-2015, 07:36 PM
BigHoss_27's Avatar
Upon take double cardon joint apart the grease fitting that goes to the center bearing. It was broke off where can I get another cause as of now all the grease is getting pushed out and won't last long
Old 04-13-2015, 08:50 PM
fierohink's Avatar
Use an E-Z out to remove what's left of the grease fitting. Any auto parts store will have replacement grease fittings. You may have to buy an assortment as I can't recall the size if that fitting, or if you can get a big enough piece of the old fitting you could match it up.
Old 04-14-2015, 05:16 AM
BigHoss_27's Avatar
Couldn't get any from auto parts store to go in the old is fine threads and auto parts look coarse
Old 04-15-2015, 06:20 AM
BigHoss_27's Avatar
And also anyone know where I can get the matsuba uj236 I joint for double Cardin joint for drive shaft Or has anyone used neapco
Colington
10-12-2015 05:41 PM
Gamble_STi
07-01-2015 12:51 PM
merc1100sc
06-26-2015 05:24 PM
cchinny
06-25-2015 08:11 PM
Quick Reply: 95 taco 4x4 reg cab rear drive shaft
