91 pickup ?'s
91 pickup ?'s
I'm looking at buying a local yota pickup.
Specs: 91 SR5 5-spd 4x4
What trans & t-case does it have? What's 1st gear, 4x low, and what are the diff gears?
Thans a bunch.
Thans a bunch.
Should be an r150 hooked to a chain drive case.
The transfercase is actually slightly lower geared than a gear drive, but I don't remember the number; 2.93 vs. 2.8 or something like that. First gear in the tranny is 3.83.
Check here to get info so you find out the differential gears it came with:
http://www.brian894x4.com/Gearratiosanddiffs.html
sr5s didn't come with 3.0s. it's just a trim package after '83 on 4x4 trucks.
it can be a 2.4(which would have a W56 and a gear driven case, or a G58 with a chain driven case if it has ADD) or a 3.0(which would have the R150F/chain case)
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
