91 4Run - wont take freon charge.
Old Oct 2, 2004 | 11:32 AM
sarasota4runner's Avatar
MY OLD R12 SYSTEM IN MY 91 4RUN WAS STILL FUNCTIONING, BUT WAS "DECLINING IN PERFORMANCE"
I WOULD NOTICE A SEVERE DROP IN COOLING, BUT BY CYCLING THE A/C SWITCH OFF AND ON, IT WOULD START WORKING AGAIN (A LITTLE)
I DECIDED TO DO THE R134 RETROFIT.
EVAC'D THE SYSTEM, PUT IN A NEW DRYER, PUT THE RETROFIT FITTINGS ON, BUT WHEN I WENT TO ADD THE FIRST ESTER OIL / FREON CHARGE, THE SYSTEM WOULDNT TAKE IT.
IM ON THE LOW PRESSURE SIDE (SIDE WITH THE RUBBER HOSE), ENGINE RUNNING, A/C ON.
IVE DONE THIS RETROFIT BEFORE ON SOME OF MY OTHER TOYOTAS, AND HAD SUCCESS.
I DO REMEBER DOING WORK ON ONE YEARS AGO (R12 AT WALLY WORLD DAYS), AND I THINK THE SAME THING HAPPENED.
IF I REMEBR RIGHT, IT WAS THE "expansion valve", AND IT WAS A PAIN IN THE A$$ TO REPLACE .
THIS SOUND RIGHT TO YOU A/C GURUS? OR IS THERE SOMETHING ELSE THAT WOULD PREVENT THE SYSTEM FROM ACCEPTING A FREON CHARGE?
Old Oct 3, 2004 | 02:44 AM
OOOPS! Sorry, it appears that I am yelling, but I have an injury to my left hand, which makes it hard to use, and type properly, so I just leave caps locks on normally.
Here's a pic of the injury - [Peice of glass broke while I was holding it]
Old Oct 3, 2004 | 04:10 AM
Cebby's Avatar
Damn! Nice carnage!!!
Sorry I can't help, but my AC is out of R12 and I need it recharged too. I want to stick with r12 though as I've heard the r134a doesn't stay as cold. Why did you opt to make the switch?
Old Oct 3, 2004 | 12:06 PM
nunsa's Avatar
Greetings,
Nice Pug! Did you try increasing the engine idle like 1500 or so? Try that it usually works. I retrofitted mine awhile ago and had no problems, but mine would not acccept a charge until I had the rpm's up to 1500 or so.
If this doesn't work, your expvalve needs to be rred like you said!
Good luck!
nanhodges2733
May 29, 2020 03:28 PM
DiggnDeep
Sep 3, 2015 02:45 PM
klavender1
Aug 15, 2015 01:51 PM
stock87yota
Jul 31, 2015 10:08 AM
photomike72
May 16, 2005 05:04 PM
