90w gear oil for rear diff
Old 02-23-2005, 06:06 PM
obscurotron's Avatar
I noticed Toyota changes the rear diff fluid spec for 2004. Now you're supposed to run straight 90w in the rear for temps above freezing, and 80w-90 for temps below freezing. So, I went looking for 90w.
Dealer was a no go (tried 2). They had 80w-90 only.
NAPA - no dice. Guy looked at me like I was an a**hole until I showed him the damn book.
Kragen - why did I bother? I should know better.
Anyone know where to get this mystical crap? Would running 80w-90 be a bad thing? Anyone know why they went from 75w-90 to 90w like this?
Bah. STANDARDIZE, DAMMIT! (this is like the red/pink coolant fiasco)
Old 02-23-2005, 07:07 PM
Nic
Nic's Avatar
I don't see why 80W-90 wont work. I talked to a parts guy at the dealer last year. I was looking for 80W-90 for my rear diff and could only find 75W-90. He nonchalantly said, "Oh we don't use 80W-90, we put 75W-90 in everything." I seriously doubt they have changed since then.
Old 02-23-2005, 07:50 PM
Dude, I'm not trying to be a jerk, but the owners manual specifically *says* 90w above 0 degrees F. So yes, they did change it. Whether the dealers are clued in enough to follow along is another question.
I guess I'll keep calling around.
Old 02-23-2005, 08:31 PM
Nic
Nic's Avatar
I don't mean "They" as in the Toyota corporation, I meant "they" as in the dealer I went to hasn't changed. If that's what you want to put in it, I understand, but my point was 80W-90 should be work just fine.
Old 02-23-2005, 09:02 PM
kevin444's Avatar
I use redline 75w90 in my rear diff good stuff.
Old 02-23-2005, 09:47 PM
kyle_22r's Avatar
toyota probably uses 80w90 at the dealership...
i don't think you'd be hurting anything running 80w90. my owners manual says to run 20w40 oil in my engine above 10*F
Old 02-24-2005, 04:53 AM
Gotcha. Yeah, you're probably right. Oh well. Still, I wish they'd just find a spec and hang onto it. I mean, what the hell changed in the e-locker rear end between 03 and 04???? Probably nothing. Someone probably got a bright idea and decided to fubar it for everyone else.
bigjstang
08-25-2021 12:41 AM
icentropy
07-11-2015 07:21 AM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 90w gear oil for rear diff
