Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
880/906 question
#2 (permalink) |
Personal
Sales Rating: (0)
Not sure about the spacers but the "A" spring is driver side[its taller than pass side]
__________________
98 4Runner SR5 3.4L Auto Suspension: Front- OME 882, N91SC Rear - OME 891, N86 Wheels / Tires: 16x7 Cragar Soft 8 285/75/16 Sport King AT |
#3 (permalink) |
Personal
Sales Rating: (0)
I believe the 880's (fronts) should be the same, the 906's (back) should have one spring that is taller (drivers side). If you have a slightly longer front, put in on the driver side.
Measure your rig with the stock springs, if you have side that is lower before the new springs it will probably be lower after the new springs (mine was). If it is in the range of 5mm then use the trim packer. My rig was pretty level with 881/906, the 10mm spacers would have raked me slightly forward, however the lighter 880's would probably be level with the 10mm spacers, you will need longer bolts when you reassemble the strut. Your CV's should be OK with the 10mm spacers on 880's.
__________________
2002 4runner SR5 4x4 1994 Ext Cab Truck 4x4 (22R-E) |
#4 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
I have the longer bolts. I just don't want to put the spacers in and then have to take them back out. Although I suppose it wouldn't be that big of a deal since I wouldn't have to disassemble the stut again. The trim packer is a different story, I only want to screw with that once. |
#5 (permalink) |
Personal
Sales Rating: (1)
Wrong place
__________________
98 SR5 4Runner Desert Sand OME 881/890 & 04/27 Shocks Go Gamecocks! Last edited by 98SR54RUNNER; 03-31-2011 at 11:13 AM. |
#6 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Good Luck!
__________________
1997 4Runner Ltd, E-locker, SAW coilovers w/eibach coils + 906/N86C, 255/85/16 BFG KM2's, 2" square sliders, ARB Bull Bar, Warn M8000 winch, Safari Snorkel My Profile: (boring but more detailed) no comments allowed or My Build Thread: where comments are encouraged |
| Tags |
| 10mm, 4runner, 880, 880906, 881, 881906, 891, 906, cruiser, fj, kit, ome, packer, packers, trim |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 880/906 Today! | ski4run | 95.5-2004 Tacomas & 96-2002 4Runners | 36 | 05-27-2009 12:11 PM |
| OME 880/906 combo, I'm confused, HELP! | aviator31 | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 06-14-2007 06:51 PM |
| OME 880/906 installed 1999 4Runner | Godzilla | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-02-2007 10:50 AM |
| I have 2,880 reasons to love me some FJ!! | Nate C | FJ Cruiser | 3 | 03-02-2007 01:11 PM |
| Toyota to recall 880,000 vehicles IFS PROBLEMS | 4Hummer | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 05-18-2005 11:53 PM |
