85 Front Axle Service
Any of you 85 & below straight axle owners ever performed the axle service on your trucks? Is this something that should be left to the professionals or can i perform this service? And what down time am i looking at?
Any input is greatly appreciated!
X-FH
http://www.geocities.com/hawnxfactor...HAWAIIAN5.html
97 4-Runner 4x4 5-spd, SSRG Hiluxsurf badges, Welds 15x16's, BFG 285/75R16 M/T's, 99 Limited fender flares & front bumper conv., factory hood scoop, digital MSD, balanced intake/plenium & throttle body, air intake mod, husky liners, wet okole, 0"-3" front, OME & 2" cornfed rear, ect., ect....
85 Toyota P/U 4x4 5-spd., center force II, 22R w/lots of goodies but V/8 swap soon, BFG 33/12.50/15, 15x12 RTX's, 5.29's, no-slip locker, double shocks at all corners, Go Rhino axle trussus, custom dual dampers, custom axle center trackbar ect., ect...
X-FH
It is not overly technical but it is quite time-consuming, especially the first time. You need a couple key tools but you should have them on hand anyway if you have an '85:
- Brass drift punch for cone washers
- Good pair of external snap-ring pliers (the kind with a wide, flat tip)
- 54mm (2-1/8") hub socket
- M8-1.25 bolt ~2" long (thread it into the axle when re-installing the snap ring)
Thanks for the info.! I will perform this service next week on my day-off...
& i beleive i have everything including tools!
X-FH
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
