4wd Lo questions
4wd Lo questions
what is the gear ratio for 4L on a 96 tacoma 3.4?
also, does the t-case act like a transmission of sorts just by switching between the three options?
try these:
http://www.4x4wire.com/toyota/faq/parts/
most likely you transfer case reduces your gears by 2.66 (increase ratios compared to 4H)
normal gear ratio from 4H
http://www.marlincrawler.com/htm/transmission/8a.htm
gear ratio :1st 3.83, 2nd 2.74, 3rd 1.93, 4th 1.00 5th .83 Reverse 4.23
example of calculation of ratio (in this case for crawling)
http://www.off-road.com/toyota/tech/dualcase/
Originally Posted by dfoxengr
can i swap the gear for just lo range?
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
ripp96
07-31-2015 11:14 AM
ripp96
07-25-2015 02:32 PM
