4Runner T-Case Breather Extension - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-06-2007, 06:38 PM   #1 (permalink)
OSU4Runner's Avatar
Send a message via AIM to OSU4Runner
Has anyone extended their T-case breather on a 3rd gen 4Runner? I know the T-case is already pretty high up, but I'd like to do it just incase. Can I use the same union fitting on the t-case as the rear diff breather? I did some searching, but couldn't find a good write up or anything very concise
__________________
2006 Tacoma SR5 - Stock for now
2000 4Runner Limited
16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~SS 1.2 Lift~Rear Locker Mod~Surco Safari Rack~ Trail Gear Sliders~Deckplate Mod w/ True Flow~Satoshi Grille~Hayden 1678 Aux Cooler~Safari Snorkel and a bunch of other crap.....
OSU4Runner is offline
Old 10-15-2007, 01:42 PM   #2 (permalink)
OSU4Runner's Avatar
bump...nobody has done this?
__________________
Old 10-15-2007, 02:11 PM   #3 (permalink)
4Crawler's Avatar
If it is a threaded breather, then unscrew it and see if it is a 10mm thread, if so the diff breather mods would work. Otherwise, see if the cap pulls off and try fitting a hose over it. If the above are no good, try this:
Since my '85 tranny and t-case(s) have no breathers, I drilled/tapped holes for pipe thread fittings:
http://www.4crawler.com/4x4/ForSale/...Shifter/3.html
My reason for doing this is not so much keeping water out, rather in keeping gear oil fumes out of the cab, since the early boxes are vented through the shifters, the hot oil fumes can get up into the cab.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-15-2007, 02:16 PM   #4 (permalink)
OSU4Runner's Avatar
Thanks for the help....I'll check it out
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Diff Breather Extension Mod Gangus2006 95.5-2004 Tacomas & 96-2002 4Runners 8 11-01-2005 10:52 AM
diff breather extension mtxride 95.5-2004 Tacomas & 96-2002 4Runners 10 10-11-2004 08:29 PM
Rear Diff Breather Extension Darx 95.5-2004 Tacomas & 96-2002 4Runners 3 07-24-2004 04:33 PM
Rear diff breather extension complete TDiddy 95.5-2004 Tacomas & 96-2002 4Runners 11 04-27-2003 02:00 PM
Breather Extension Questions az4x4runner 95.5-2004 Tacomas & 96-2002 4Runners 11 01-24-2003 08:19 PM
2009 InternetBrands, Inc.
