4runner a/c fan no low speed
Old Jun 24, 2011 | 06:29 PM
PhoRunner's Avatar
I've searched to no avail on this, I've recently found that the "lo" speed for the vent fan on my '01 4runner doesn't work. The other settings work fine, so I've been using the second speed.
Has anyone had this problem? The fan control resistor went out on my 89 pickup a while ago, but that made it only work on high, and I assume it's a totally different fan control system.
Any thoughts?
grant
Old Jun 26, 2011 | 05:40 AM
jdmaccord6's Avatar
Same thing happened to mine, i believe it's called the blower resistor. I believe the part is less then 20$ from the dealer if i remember correctly. Takes about 10 mins to replace. Depending on which part you need:
http://www.toyotapartsales.com/partl...layCatalogid=0
Old Jun 26, 2011 | 08:03 AM
PhoRunner's Avatar
nice, so the system is similar to my old p/u. Thanks!
Old Jun 26, 2011 | 02:51 PM
yotaluver's Avatar
that happened on my wifes altima, so i'm guessing it's pretty common on a lot of vehicles
Old Jun 26, 2011 | 05:40 PM
Sensei's Avatar
Yep, blower resistor. usually below the blower fan on the firewall.
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
Mr.Black
Jun 21, 2015 10:17 AM
