YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-22-2013, 04:17 AM   #1 (permalink)
Personal Sales Rating: (0)
808-3VZE's Avatar
3.4 overheat!
My 95 tacoma overheated last night! Going up a hill noticed that the temp was getting up there so I pulled over popped the hood and coolant started to boil over from the coolant over flow. So I let it cool down added water and drove it back home. I recently done the timing belt and water pump about a month ago. Anybody got a problem like this before? Need all can! Thanks!
__________________
94 Toyota pickup 4x4 3.0v6 5spd
3" body lift. 31x10.50-15 Tires.
No cat converter single in dual out Flowmaster.
Hope to be soon 3.4 engine swap with a/c.
808-3VZE is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-22-2013, 05:46 AM   #2 (permalink)
Personal Sales Rating: (2)
Swimmerboy2112's Avatar
How is your thermostat? You said you just did the t-belt and water pump, perhaps you had an air bubble trapped in the cooling system, happens all the time.
__________________
1986 4Runner 22RE, 5 Speed, Rebuilt 22RE, Bored .020 over, 261 Cam, LCE Header, BudBuilt Skid Plate, ARB Bull Bar, Warn M8000 Winch, 2" Lift (BJ Spacers & Add-a-leafs), 33x12.5 Super Swamper TSL's, CanBack Soft Top, Roof Basket, 3rd Gen Alloys, SAS in the works!
Check out my build thread! SOLD!
2002 Tacoma X-Cab, 5VZE, 5 Speed, E-locker, Borla Exhaust, K&N Intake, Red/Clear Tail lights, Clear Corner Markers, more to come!
Swimmerboy2112 is offline
Old 01-22-2013, 06:14 AM   #3 (permalink)
400yzturbo's Avatar
When you first start the truck and as it warms up do you see the temp gauge climb in temp then all of a sudden drop in temp. If it does do as mentioned the thermistat would have just opened, potentially eliminating a stuck thermistat. also if the radiator gets hot then you know coolant is circulating.
Another idea is, a bad radiator cap can cause the radiator to push hot coolant into the over-flow and not maintain the needed pressure on the coolant system to keep it from boiling.
Good luck
400yzturbo is offline
Old 01-22-2013, 06:16 AM   #4 (permalink)
400yzturbo's Avatar
Is your engine the 3.4? The 3.4 wasn't offered in the tacoma until 96. Did you do a swap?
Old 01-22-2013, 08:39 AM   #5 (permalink)
Skidmarcx's Avatar
If you have access to a heat gun take readings from both top and bottom radiator hoses... should be at least a 30 degree difference across the radiator. Also check to make sure airflow is not impeded... the fan clutch could be to blame as well
Skidmarcx is offline
Old 01-22-2013, 11:21 AM   #6 (permalink)
Threadstarter [OP]
808-3VZE's Avatar
Quote:
I pulled it this morning the thermostat its the oem one with the little valve on the top
__________________
808-3VZE is offline
Old 01-22-2013, 11:25 AM   #7 (permalink)
Threadstarter [OP]
808-3VZE's Avatar
I just changed the thermostat and the radiator cap. The cap looked old rubber was damaged. Changed the thermostat too just in case. Filled the radiator up and let it idle for 30 minutes. Temp gauge looks good. I'm crossing my fingers!
__________________
808-3VZE is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
34, climbing, engine, hills, overheating, tacoma, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
