3/4 ontop 3"
Old 03-01-2009, 12:34 PM
darbtaco11's Avatar
3/4 ontop 3"
hi i have a 2wd 99 tacoma with a 3" skyjacker lift. is it possible to still fit a 3/4 of an inch coil spacer on or no?
Old 03-01-2009, 01:03 PM
Gerdo's Avatar
Is the 3" lift a bracket lift?
Old 03-01-2009, 01:04 PM
darbtaco11's Avatar
yes
yes it is wow sombody who finally knows what it is but yes it is
Old 03-01-2009, 02:19 PM
darbtaco11's Avatar
3/4 ontop 3"
Old 03-01-2009, 03:35 PM
waskillywabbit's Avatar
Please do not double post threads and this has been moved to the proper tech forum.
Thanks!
Old 03-01-2009, 06:16 PM
Gerdo's Avatar
Do you have any pictures of the setup and the angle of your CVs? If they are at a severe angle then no I would not add a spacer. If they are fairly level then you might be able to add the spacer.
Probably the best answer you are going to get is "sure give it a try and see if it works".
Old 03-01-2009, 06:27 PM
trd_4runnin11's Avatar
It's a 2wd. No CV angles to worry about. So yeah, you should have no problems with the spacer.
Old 03-02-2009, 10:12 AM
Gerdo's Avatar
I missed that. It is 2wd. I would agree, probably no problem adding the spacer.
Old 03-02-2009, 01:06 PM
darbtaco11's Avatar
ok thanks yall i will tell what happens when i puti it on
JUICE222
10-13-2015 08:50 AM
old87yota
09-09-2015 12:39 PM
Kreedy1
09-08-2015 06:33 PM
sniper34639
08-31-2015 07:56 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: 3/4 ontop 3"
