3.0 idle adjustment
Old 12-22-2003, 08:04 AM
SolidDigital's Avatar
3.0 idle adjustment
hey, anyone here ever adjust their idle on the 3.0? from what I could see there were two screws to do this... the first and most easy for me to get to would rest on that spring thing so it doesn't seem like it'd work too well just tightening the one..
i don't have the right tools to get to the second one that seems to be metal on metal instead of metal on a plastic type of spring...
anyway I was wondering what type of tools you might have used to do this and if you tightened both or just one?
my truck will sometimes idle as low as 550 rpm's and I'm trying to bump it up to 800... I've already tightened the adjustment on the throttle cable as much as possible so the adjustment on the throttle body is my only option now..
Old 12-22-2003, 09:01 AM
Co-Founder/Administrator
Staff
Corey's Avatar
There is only one screw to adjust your idle on the 3.0
Here it is.
Very easy to do.
Old 12-22-2003, 09:07 AM
tenfourtyeight's Avatar
Where could you do this on a 22RE? My truck idles pretty low also. Feels like it is almost going to stall sometimes. I hope it's just an adjustment and not a problem.
Old 12-22-2003, 12:39 PM
Thanks! I never even noticed that before:pat: just went out there and adjusted it a little bit, noticed if I turn it too much one way or the other something seems to whistle/hiss like there's a vacuum leak or something.. is that normal?
Charecter1
11-06-2023 10:08 AM
Alex Bessinger
08-31-2015 09:17 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: 3.0 idle adjustment
