2nd gen pitman arm???
Old 01-01-2004, 08:13 AM
Marc P's Avatar
I noticed that I have quite a bit of play in my pitman arm. I have found an aftermarket one for about $40. It looks easy to replace, but is it?? Anyone else replaced theres? I tried a search, but found nothing.
Thanks in advance for any help?
Old 01-01-2004, 08:39 AM
Leaf's Avatar
Did you notice play in the arm while it was on a lift or on the ground?
I used this at autozone.com for troubleshooting: http://www3.autozone.com/servlet/UiB...3d800501eb.jsp
Lots of good stuff on that site, good luck.
-Leaf
Old 01-01-2004, 04:41 PM
Los Gatos?'s Avatar
The pitman arm can have play in certain directions before it needs replaced. I forget which direction is the bad one, I think it is allowed a certain amount of horizontal "front-back" movement but I'm not exactly sure.
Old 01-01-2004, 05:03 PM
Cebby's Avatar
Re: 2nd gen pitman arm???
SUre it was your pitman arm and not your idler arm?
Old 01-01-2004, 05:06 PM
Marc P's Avatar
I noticed that if I grab the passenger tire and move it back and forth, the pitman arm has quite a bit of movement in it. The idler arm is connected to the steering box, this is the other one on the pass side.
Old 01-01-2004, 05:18 PM
Cebby's Avatar
I am nearly certain the idler arm is on the passenger side. I think the pitman arm comes off the steering box. If you can move the idler arm much at all, it should be replaced. I had mine done about 6 months ago.
Old 01-01-2004, 06:18 PM
AgRunner06's Avatar
I'm 100% certain that the pitman arm connects to the steering box and the idler arm is on the passenger side. What you need fixed is the idler arm.
Here is a write-up on how to rebuild it. I followed the directions without any problems. I think it only cost me about $12. It's very easy to do.
Good Luck
Old 01-01-2004, 06:49 PM
RobT2k's Avatar
You better stop taking it offroad, you're starting to break stuff.
J/K, is there a wrenchathon in the works?
Old 01-01-2004, 06:52 PM
Marc P's Avatar
My bad--thanks for the link to the write up. That seems pretty easy and cheap.
89fourrunner
02-17-2016 06:52 AM
I8URSVT
09-03-2015 11:42 AM
nick9455649
08-29-2015 02:08 AM
vanion2
07-29-2015 06:17 PM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: 2nd gen pitman arm???
