265/70-16's vs. 265/75-16's?
Old Nov 25, 2004 | 05:24 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
What are the pro's and con's of changing from my stock size 265/70-16's to 265/75-16's? I'm figuring my speedometer will indicate about 2 mph less at 60 mph.
Old Nov 25, 2004 | 05:59 AM
hotshoe's Avatar
Tires
I did the same swap on my T100 and the only change I saw was the auto trans seemed to "hunt" for the over drive more often. Looks 10 time better with the wheel wells filled up. Good luck!
Old Nov 25, 2004 | 06:20 AM
aowRS's Avatar
I've read that the stock speedo shows high from the factory - so changing to a slightly larger diameter tire actually brings the reading closer to actual. I went from the stock 265/70s to 275/70 REVOS - and love them.
Andreas
Old Nov 25, 2004 | 07:02 AM
mtxride's Avatar
Andreas
that's what happened to me. According to my gps, my speedo is more accurate now with the 265/75's... it's now like 1 mph slow vs. 4 mph fast with the 265/70's.
Old Nov 25, 2004 | 10:57 AM
Ontos's Avatar
I had the exact same thing happen to me.....GPS showed a little slow w/70's, but it's right on now with the 75's. Seems I lost just a little power on grades, but I could be imagining it, as I was kind of expecting that to happen. However, after the header (it's a 2.7L so headers wouldn't really be appropriate, huh?) and cat-back, I'm probably doing a little better than before the swap. Go for the 75's....it's a good choice
Old Nov 25, 2004 | 11:04 AM
Kcannaday's Avatar
Buyem, You'll be glad you did! I went with the Bridgestone Revos in a 265/75/16 on my 99 4Runner and lovem, my speedo is on the money now also.
Old Nov 25, 2004 | 11:25 AM
02SE's Avatar
I have LT 265/75R16 Toyo Open Country AT's on my '97 runner, They look good, and work very well.
Old Nov 25, 2004 | 02:43 PM
lee's Avatar
lee
yea, whats been said (by you & others) is pretty much it for pros and cons. they look awesome, but speedometer is messed with a bit. also, there can be rubbing at full lock turning.
but who cares when it looks so good
i want 265/75/16 bfg t/a ko's, in case i havent said it enough (look at my sig!)
Old Nov 25, 2004 | 06:52 PM
Rick F.'s Avatar
Thanks, gents. I've been having trouble finding a particular tire in the 265/70-16's anyway and the 75 series are in stock.
I don't need to mention that YotaTech is the BEST!!!
Old Nov 25, 2004 | 07:33 PM
awoods's Avatar
just got that 265/75/16's about a week ago and love um. i got the yoko geolander at plus two's. look nice in the well. slight rubbing, which gives me an excuse now to lift
buy um
Old Nov 26, 2004 | 12:21 PM
LarsDennert's Avatar
Dirty pool from Toyota. Makes people think they are getting better mileage than they really are. I noticed the same from my speedo. You'll get very minor rubbing on the plastic with the +1 size. Definately worth it though.
ashamsuddin
17
Jul 22, 2024 03:59 AM
shisha1999
Sep 21, 2015 08:22 PM
mxdw88
Sep 20, 2015 03:13 AM
AndYota
Aug 10, 2015 09:19 AM
msane99
Jul 11, 2015 08:08 PM
