2002 Tacoma ISR and Elbow Mods done
Originally posted by Tacoma Dude
Anyone losing power with the ISR mod?
I'm only on my 2nd or 3rd tank of gas since I did mine but while I was driving on the freeway I had my cruise control set on 65 and everytime I hit a hill the RPM jumped from a little over 2K to 3K+!!!
I don't remember this ever happening with everything stock. :cry:
Is this normal? Am I still in the break-in period?
As you know, I have done some testing, and only found positive results with the ISR mod, uncapped.
Originally posted by ALBPM
I want to replace that huge Monza tip on mine with a slant cut stainless tip.
Summit Stainless Tips
I actually want to replace mine with a stainless one at somepoint, its starting to rust pretty good on the bottom. Let us know how you like those Summit tips.
Originally posted by <96 Runner>
Are you "capped" or "uncapped"? The only thing I could attribute it too is running richer at low RPM's, which bogs the engine a bit, and if you have an AUTO (I am assuming you do), then that may cause the computer to kick down a gear when it normally would not.
Oh yeah, yes, I have an auto.
I'm running uncapped but the vaccuum tube I used is fairly narrow - I couldn't find a larger nipple to run from the plug so I had to resort to one about 1/2 the width. Hmmmm maybe I should make the same run capped and see if there's a difference.
#25
I think it was your image on one of the recent threads about this <96>?
Anyhow, I patterned mine after that.
I'm running into problems finding an adequately sized (width) nib to attach to my cap.
I'm finding nothing out here.
#26
#27
Well, I have yet to check out Lowe's... the nearest one is next to the Q (this year's Superbowl).
Home Depot has been close to useless but I may check it out again...
I've been using some drip thing too (sprinklers) but it's pretty narrow. I think I'll be checking out what I can find today while I go look for a deckplate.
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
12-29-2015 12:44 PM
Poncho0206
07-10-2015 06:21 PM
