2000 4Runner Vibration/grinding Noise
Old 03-08-2008, 08:04 AM
jfond's Avatar
I have a 2000 4Runner and it has a Vibration/grinding Noise when the car is cold that is quite loud and can be heard for about 3-5 minutes after you start the car, and can be heard in the car. I have looked under the hood and do not hear anything. In addition, when driving, the Automatic Transmission does not always smoothly shift gears and goes up to 4500 or so RPMs before shifting.
Are these 2 issues related? Am I looking at a major repair?
Old 03-08-2008, 09:23 AM
Skrillah's Avatar
If its shifting that way only when the engine is cold then no, thats a not a problem. Thats how its suppose to shift...
How many miles do you have?
Where is the vibration, grinding noise coming from?engine area? underneath? While driving? just idling?
More details!
Old 03-08-2008, 09:38 AM
jfond's Avatar
It is shifting that way at various times, hot and cold, I want to add that it hasn't done this until recently - I should also add that at times when you press on the gas that the RPMs sometimes jump way up like 6000 + RPM
110,000
It is coming from the front of car torwards the back of the engine area
Old 03-11-2008, 10:45 AM
jfond's Avatar
Any Ideas?
Old 03-11-2008, 03:48 PM
Ultraman V's Avatar
Sounds like a torque converter going bad...or....when is the last time you've changed the tranny fluid?
Old 03-12-2008, 07:12 AM
jfond's Avatar
Tranny Fluid was done about 6,000 miles ago. I was worried it could be Torque Coverter - AS not having one of those go out before - if it goes - I'm dead on road, correct?
Any idea what the cost is to have that replaced - I am not mechanical enough to do this myself.
Old 03-12-2008, 07:36 AM
97ltd4x4's Avatar
I doubt its the torque converter.Usually if it fails you will have no forward or reverse gears,If the torque converter lock-up clutch fails it will bang or shutter when it engages.The sliping it what would concern me the most.Pan needs to be removed and inspected for debris.How is the fluid? Its possible that if the fluid is in good shape and no debis is found it could be a valve body problem.I suspect that a new/used trans is what you are going to need.
Remember a trans,Is like a woman.......If its pink,and it don't stink..It's good!
Old 03-12-2008, 09:29 AM
jfond's Avatar
it sounds not too good either way... which is what I was afraid of
mskalmus
05-28-2017 07:51 AM
razorman8669
07-12-2015 12:13 PM
Avenged
07-09-2015 07:55 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 2000 4Runner Vibration/grinding Noise
