Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
2000 4runner ATF fluid level
__________________
WTB: ARB RD90 FS: 8" V6 Turbo 4.56 OEM geared 3rd differential |
#2 (permalink) |
Personal
Sales Rating: (0)
Trans should be in nuetral when you check it....not in park.
__________________
05 Tacoma D-cab TRD Sport Longbed -DD, lots-o-mods. 02 4runner Sport Edition - Wife's kid hauler 86 4runner - 22re, automatic, 5.29 gears, Aussie locker, 35x12.5" Goodyear MTR's, BJ spacers, Doetsch Tech 8000's, Downey T-bars & idler arm brace, custom heim joint TRE's. All-Pro leaf springs w/ Billy 5100's, 2" 4crawler BL, 2" drive train lift w/ Budbuilt crossmember, 4x Innovations DOM sliders, 130 amp alt. Custom gauges, Cobra CB, Firestick. My Build |
#3 (permalink) |
Personal
Sales Rating: (0)
before you checked it did you wipe of the stick then put it back in? this will give you a better reading on the level.
__________________
94 pickup 22re, rear locker and 30x9.50 tires. "everything you do to your truck makes me want to facepalm... but, hey, its your rig, so do what you do..." -space-junk |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
Duh... moron, I warmed it up but then shut it off while checking. back to the garage!
__________________
#5 (permalink) |
Personal
Sales Rating: (0)
Yes it should be running and in nuetral.......set the E-brake.
__________________
#6 (permalink) |
Personal
Sales Rating: (0)
Actually, it should be fully warmed up, running, and in park, not neutral. And go through the gears slowly before putting it in park the final time. Oh, and make sure you're on a level surface.
__________________
1999 Limited 4x4 w/locker, 2-tone slicktop. |
#7 (permalink) |
Personal
Sales Rating: (0)
Might be right ^. I'm going to double check. Now that you say that I don't remember exactly what I did on my wifes 4runner. Sometimes I work on so many veichles that I forget what is what.
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
its more of a hot cold check, the auto trans on the lux has a wet sump so the oil drains to the bottom of the gearbox when not running so do a cold check first ie first thing in the morning, then warm up to operating temp then slowly work your way through the gears front to back front to back on the shifter this makes the oil from the sump go through all the valves and through the gearbox when runnig this is your warm check, the level should be half up the dip stick or close to warm once you have warmed the engine up, if its closer to cold on the dipstick on the warm check you need to add more atf fluid, fill it in small 0.5 ltrs chunks or risk over filling.
#9 (permalink) |
Personal
Sales Rating: (0)
Hot, running in Park, having run through all the gears is how I have checked ATF fluid for 20 years.
For the 4 Runner, my reads about 1/4" from the lower HOT hashmark. Shifts fine.
__________________
99 Limited 4WD in Autum Blaze Mica |
#10 (permalink) |
Personal
Sales Rating: (0)
What would happen if it was slightly overfilled? Say 1/4 qt or so. Would it shoot out of the dipstick hole or something?
__________________
1999 Gen. 3 4Runner: 3RZ-FE 2.7 L: 200k miles (automatic; base 2WD) 1999 Gen. 3 4Runner: 5VZ-FE 3.4 L: 200k miles (automatic; SR5 4WD) "Why buy one when you can buy two for twice the price?" |
#11 (permalink) |
Personal
Sales Rating: (0)
if its very slightly above the mark it shouldnt be anything to worry about if its a lot over the mark you could blow all the seals in the gearbox damage valves and the internals of the gearbox, if your worried then drop some fluid out of the gearbox to be safe same sort of task as dropping your engine oil. if your going to drop the lot then you will need to bleed to the auto box back up once the new fluid is in.
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
J2F42C is exactly correct per the FSM. Engine running, in park after cycling through the gears. If you want to be REALLY anal the fluid temp should be 165* F +/- 10*.
Like the thread started my fluid was off the charts high. Drove and shifted but not well. I've slowly been flushing (drain 4qt, dilute add 4) and the difference is amazing. Proper levels and Valvoline Dex/Merc III Max Life and it sometimes shifts now without me even feeling it. Here's to another 170K mi, just hoping there wasn't too much damage by the over filled levels.
__________________
| Tags |
| 02, 1999, 2000, 4runner, 99, air, atf, cold, drain, drop, fluid, fluids, level, leveling, runner |
