2.7L Stalling, Cutting, Runs Rough
Old 12-02-2012, 08:51 PM
Whooker23's Avatar
I have a '95 Tacoma, 2.7L. It runs awesome for about 10 minutes til it gets warm then it starts stalling and cutting out on me driving down the road. Barely idles and acts like its going to die. The ignition rotor was bad I replaced it but I can't seem to figure this out. Please please help
Old 12-03-2012, 06:55 PM
xcfunrunner's Avatar
When I had an '88 Pickup with a 22re, I had a similar issue to that. My truck would run great when it was cold but once it got warm, the idle would stumble around and rise and fall, almost killing the truck. For me, replacing the Coolant Temperature sensor worked. It is one of those parts that just "fails", like a light bulb. It works by providing different resistance levels to the computer when it is warm or cold. Might want to investigate that. It was about $15 at autozone for mine. You can test it by running a resistance multi-metere to each electrode. Place the sensor in hot water and then place it in cold water. There should be a significant difference in the resistance reading. Just an idea though. Mine never threw any codes or lights.
Old 12-03-2012, 06:58 PM
Whooker23's Avatar
Thanks for the input! Appreciate it!
Charecter1
11-06-2023 10:08 AM
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
Nickdigg
07-07-2015 06:04 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 2.7L Stalling, Cutting, Runs Rough
