15x10 or 16x8?
15x10 or 16x8?
I found the wheel I'm going to go with but not sure on the size. 16x10's aren't offered in the style I want. They're the same price and I'd be putting 33" tires on no matter what size rim. 15x10's only come in polished aluminum, 16x8's are chrome or polished. So let's hear it; what are the pros and cons of each: 15x10 and 16x8? Thanks
Zach
Zach
Originally posted by Victor
285/75r16 will fit on the factory wheels.
Depending on backspacing, 16x8s will cause the tire to constantly rub on the upper A arm/ ball joint area. Like Darren said, forget 16x10s unless you run wheel spacers and bash the heck out of the front fenders.
I've seen stock wheels on 3rd gen Runners where the top of the front tire is so close to the upper A arm that you can't fit your little finger in between.
about the 3rd gens, I've seen the same thing too. isn't that on the ones that use the stock wheels and cram the 285/75's onto them? I know that was one thing I looked at and one reason I got different wheels. according to my measurements I was increasing my section width by 2 inches and with my 265/75's I was only about an inch from the arm. that means the 285's definately would have touched at least at one point during flex.
I'll double check but I have tons of room with the 2002 wheels and my 2nd gen arms. Finally something we 2nd genner s have on you supercharged demons!!!
I was merely celebrating that I don't have to envy you 3rd genners in one category. You guys have the better engine, supercharger, and the electric locker. Those are all things I'd love to add to my truck someday.
I can't believe no one asked if he had the sport package. If so, he CANNOT use 15 inch wheels at all, in any width. The brake caliper is just too big on the sport and highlanders to go down any wheel size at all. That is why they come with 16s to begin with.
16s look better anyways
Re: Wheel spacers
Originally posted by White SR5
Wider stance = better. Wider tires = worse. Where to find wheel spacers = I don't know. Yotatech = answer (hopefully).
Zach
Zach
MxPx_Reaver
07-01-2004 07:22 PM
bigKahuna
09-29-2003 09:48 AM
