02 sensor
02 sensor
anybody know how much an o2 sensor costs? and is it easy to replace? have a 98 4runner 4 cylinder. could i buy the part and do it myself?
about 120 for dealer cost, 2 new nuts, and gasket
ez to replace
need a 12mm box wrench, or small vice grips
may need a small chisel to chip off the old nuts
then you need to scrape the old paper gasket off
so the bung is 100% smooth. again, chisel is great for this
new o2 sensor, new gasket, 2 new dealer stainless steel nuts
just climb under there and crank it off.
use eye protection a lot of crap will fall on you
ez to replace
X2 on the eye goggles.
I've used www.1sttoyotaparts.com before and been pleased. They are the online department for a WA dealership. Usually have cheaper prices than your local dealer, and lower prices than your local dealer's online dept, too.
Did a quick check, looks like it'll be about $100, probably add $10 for shipping. Call the local dealership to get th correct part(s) number, then look around online, usually saves some $$$ if you can wait a few days.
zz_denis
09-06-2015 03:43 PM
