02 4runner problem
Old Nov 13, 2007 | 05:45 PM
killa b's Avatar
02 4runner problem
just got my runner about two weeks ago so not very familer with them. so about the problem when ever im stoped while in reverse or in drive there is a clicking/knocking noise. but when im in netural or park no noise. also i can feel it knocking in the 4wd shifter more than in the regular shifter. thanks
Old Nov 13, 2007 | 06:26 PM
Nate08's Avatar
Is it full on transmission fluid? Maybe it's missing enough to make it "knock"?
Old Nov 13, 2007 | 07:32 PM
killa b's Avatar
to my knoledge i belive so it does look dirty. you check it in neutral running right.
Old Nov 14, 2007 | 07:43 AM
eric-the-red's Avatar
No, you check it in Park, with the engine running. Also you want the fluid warm, not really hot. Take it for a drive and warm up the trans, then wait 10-15 minutes and then check it.
As for feeling it in the 4wd shifter and not the trans shifter that's because the 4wd shifter is directly connected to the transfer case, whereas the trans shifter is connected through a linkage. I have an 01 and get a slight vibration in the 4wd shifter, but nothing in the trans shifter.
Old Nov 14, 2007 | 05:45 PM
killa b's Avatar
its a knocking like a thump. park and netural are the same differance.
Yota.Jay
Jul 23, 2015 08:08 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
