00 to 01-04 Conversion
Old 12-17-2009, 07:23 PM
ovrebo1's Avatar
I might be picking up a 2000 Taco and I was wondering what i would need to convert the front to a 01-04 and if the tailights from a 01-04 would bolt right up.
-Thanks
Old 12-18-2009, 06:43 AM
ovrebo1's Avatar
Bump..
Old 12-18-2009, 07:24 AM
Staff
DeathCougar's Avatar
Ok, there is a very complicated and arduous process. I'll out line it for you, and do my best to be thorough.
  • Remove old taillight using #2 phillips screwdriver. 4 screws total
  • Unplug connector from old taillight
  • Plug connector into new taillight
  • Install 4 screws using #2 phillips screwdriver, 4 total. Tighten in a disgonal pattern starting in the right upper, and ending in the left upper corners
The ONLY difference between the two is ONE longer screw in the 01+ taillights, so make sure you compare or your truck could EXPLODE!
Old 12-18-2009, 10:37 AM
Ritzy4Runner's Avatar
Oh ..... I don't know about that Cougar ... you had better be sure to check that against the FSM (Factory Service Manual) Hate to think you may have missed a step!
Old 12-18-2009, 10:49 AM
Staff
Actually, you are right I did miss a step.
-Step 5; Drive the Tacoma to the mall and test out their RTI curbs
Old 12-18-2009, 12:09 PM
CYi5's Avatar
You forgot to outline doing the front conversion, but cute response regardless.
Old 12-18-2009, 03:13 PM
Staff
I was not trying to be cute, I was merely outlining the necessary steps to the taillight conversion!!
As for the front end conversion, it has been covered before.
Quick search in the "Tacoma/4Runner" section using "tacoma conversion" for keywords brought up this thread: https://www.yotatech.com/forums/f2/o...thread-163883/
And here on Cardomain: http://www.cardomain.com/ride/2249910
They tell you exactly everything you need to do. I would suggest sticking to OEM parts, the aftermarket parts fitment is terrible.
Also, next time, SEARCH
Old 12-19-2009, 04:40 AM
ovrebo1's Avatar
Thanks
Old 12-19-2009, 05:32 AM
bain's Avatar
Budbuilt did my conversion...You could email him and he would be happy to tell you what he did..
justdifferentials
14
06-11-2017 08:36 PM
live4soccer7
05-11-2016 06:52 PM
runnermedic
13
09-21-2015 05:20 PM
Gurr
09-12-2015 09:51 PM
Quick Reply: 00 to 01-04 Conversion
