Sullivan's 92 Pickup Build Thread
Picked up this 92 Toyota 22r 5spd for $500. truck has 240xxxkm on it, has unpainted replacement doors fenders and box sides. Plan is 3 inch body on 33's then safety the truck and put a 4-5" lift staying with ifs, then regear an 37's. ive only had the truck for a week now so not too much done yet
ill explain whats been done in each pic.
Day i got the truck
checkin out sills ect
sand and prime (as you can see rockers are gone)
rockers cut out for steel sliders
3 inch body lift, and 33's on
The truck bed was absolutely rotten, and with no boxes anywhere around here. i decided to make my own truck bed, and ill be putting the box sides on aswell
started painting the frame yesterday
also the truck is getting full MTX marine audio these 300 watt per speaker in the back on the roll cage in the cab. then a 10 inch mtx marine sub and amp, all waterproof
hopefully ill have more progress up tommorow!
Day i got the truck
WELL heres an update.
got some what i believe to be dayna 44's (havent looked into it)
box frame is done
tonne of painting done and rust control
shaved fuel door
box frame is done
shaved fuel door
well i put a new battery in the truck and now it doesnt wanna stay running... ran for like 5 min then just shutoff now it wont run for more than a 5 seconds or so.... started raining so ill work on it tmrow
yes the blocks do measure 3", and thanks for the battery connection tip ill check it out tommorow. also the box wasant to bad to fab, i cant wait to turn this truck into a weekend toy
well i was pullin off the head today to do the headgasket, well the head is cracked, piston is #1 is chipped and cracked down the middle aswell. also the timing chain guides are no where to be found. looks like ill be buying a new longblock from daves performance in the near future
well motor is out, and tried the tremclad roll on method with some semi glass black... not happy gonna sand it with 400 and spray it at my buddies place in a few weeks.
well today i bought a 94 22r auto 2wd with a mint cab minus the rad support due to a front end collision, but interior is mint rockers are mint tinted windows ect. now i gotta swap the cab and motor over to the 92... also have to look into what i all need to switch out for cluster, pcm, harness ect.
well the 2wd is stripped and frame cut up ready to go to scrap, got the 2wd cab on today, im also now using the 2wd box with my boxsides... tommorow there should be an huge update as me and my buddy are gonna work on it all day, also built a pretty snazzy bumper lol.
06-01-2021 01:51 PM
tpd143
07-07-2015 09:06 AM
