Jthod's '94 4Runner build
Old 03-06-2014, 06:35 PM
kornhuskerwizard's Avatar
Im doing a 4.3 swap. ls swap much more wiring and clearance issues. This sounds like a pricey build.
Old 03-06-2014, 07:11 PM
Jthod's Avatar
I got great deals on most of the parts. I like wiring, and have access to all the necessary diagrams.
Engine was a core $125, plus $300 in gaskets, bearings and oil pump.
Trans was $75. Rebuild parts were $450, which is a lot, but shout be a very stout tranny.
Transfer case, $60
14 bolt $100, pulled.
Dana 60 is gonna kill me
Old 04-04-2014, 06:42 PM
Jthod's Avatar
Dana 60 acquired. 4.56s, Spicer lockouts, came with srw hubs, needs pinion bearings, and maybe king pins.
4L60 is mostly together. Just need to finish up the shift kit on the valve body. All ne seals, ans clutches, many upgraded parts. Corvette servo, zpack 3-4 clutches, and larger pump boost valve.
Picked up a vss np241 from a 91 suburban a few weeks ago.
Should be getting the 14 bolt next weekend, also with 4.56s.
I think I'm going to go with skys offroad full width kit, and find some srw hubs for the 14 bolt, H1s should make the width about where I want it. May end up taking 2" off the long side of the 60 to narrow it up a bit.
Old 04-04-2014, 08:35 PM
Sounds like a good build.
Old 04-04-2014, 08:51 PM
  #25
Jthod's Avatar
Thinking about taking a couple days off and getting the axles under it when I get the rest of the parts. Need to track down some front springs still.
Have a pair of 63" springs and a transfer case adapter I need to pick up in Omaha sometime.
Old 04-07-2014, 01:41 PM
  #26
So go gettum!!
Old 04-08-2014, 05:40 PM
  #27
Jthod's Avatar
turns out they weren't 63"s, and won't return my messages about the adapter. FAAK
anyways greasy old 241
transmission complete
getting the D60 torn down. Gears look good, pinion bearing shot, lockouts were a rusty mess, but they came apart.
Old 04-08-2014, 05:44 PM
  #28
Thats a beefy a$$ frontend
Old 04-09-2014, 05:55 PM
  #29
Jthod's Avatar
Should be up to the task.
Old 04-09-2014, 07:34 PM
  #30
Jthod's Avatar
Going to be tearing into this in the near future. If anyone is interested in any of the stock parts pm me.
Engine - blow'd up, but all accessories will go with.
Trans- works great, shifts perfect.
Transfer case - same.
Front and rear axles - couple leaky seals but good otherwise.
Wheels and tires. Aluminum 15x8" wheels. Good BFG all terrain 31x10.50-15s, great tread, quiet, even wear.
Shocks and lift parts all around- ball joint spacers and rear spring spacers. KYB mono max shocks
Old 04-11-2014, 08:33 PM
  #31
WVYOTABOY29's Avatar
Loving the runner. The engine rebuild sucks doesn't it. I'm getting ready to do it to my truck. It has 423,097 miles on it. I'm surprised it lasted this long.
Old 04-11-2014, 08:36 PM
  #32
Do you by chance have any lower control arms or cv axles.
Old 04-12-2014, 05:02 PM
  #33
Jthod's Avatar
Better swapped that rebuilt!
I will have the complete front and rear suspension for sale as soon as it's pulled
Old 04-12-2014, 05:11 PM
  #34
Jthod's Avatar
Also, picked up another piece to the 1TONTOY puzzle.
I figure project 1TONTOY had a good ring, and hopefull license plates later this year.
Old 04-14-2014, 05:56 PM
  #35
Jthod's Avatar
14 bolt dropped in the shop, Dana 60 stripped.
It looks to be in decent shape. The gears look good, pinion bearings are loose, but carrier side bearings are good. The passenger side king pin has been apart, and looks to be newer. Drivers side, not so much. The bushing was broken, and it was kinda crusty in there.
Old 04-14-2014, 06:04 PM
  #36
More progress!
Old 04-14-2014, 06:33 PM
  #37
Jthod's Avatar
What a pile of parts I have...and much more to order.
Looking for some ruf springs, srw 14 bolt hubs, 8x6.5 lug wheels for rollers, 63" 4x4 leafs.
Old 04-16-2014, 05:20 PM
  #38
Those axle pieces look good! I'm no longer needing parts anymore went and got a parts truck. 300$ later and, Name:  imagejpg2_zps299cc43b.jpg
Old 04-17-2014, 07:48 AM
  #39
kelvinb's Avatar
where from
Old 04-17-2014, 07:49 AM
  #40
kelvinb's Avatar
i have an extra set of poly bushings if you get some 88-98 springs
Quick Reply: Jthod's '94 4Runner build
