4x4yota's 94 SR5 4runner
Old 06-12-2014, 02:46 PM
Roark's Avatar
What else has happened with the 4Runner>
Old 06-12-2014, 05:12 PM
4x4YOTA's Avatar
nothing other than collect parts... she has been sitting for about 3 months waiting for a new heart since she blew a head gasket...
parts collected
3.4 V6
85 solid axle
E-locker
3rd gen 16" alloys
LC coil springs
few SAS parts
Old 06-13-2014, 05:17 AM
Gizler00's Avatar
Awesome. I love collecting parts when getting ready for a build. Makes things go so much smoother when the time comes to dig in.
Old 08-01-2014, 02:21 PM
4x4YOTA's Avatar
having a complete donor rig is very convenient but tear down is no picnic...
got it mostly stripped but now i am moving to a house with a garage so maybe the progress with speed up
Old 09-01-2014, 06:19 PM
  #25
4x4YOTA's Avatar
started pulling apart the 3.0
amazing this thing was still running timing belt is trashed
Old 10-25-2014, 06:39 PM
  #26
4x4YOTA's Avatar
3.4 ready to go
3.4 in
start of SAS
Old 10-27-2014, 09:10 AM
  #27
4x4YOTA's Avatar
so I am looking into wiring up the engine and need some advice if it is simple enough to do myself or pay ORS to build me a harness I am very skeptical when it comes to electrics but I have wired winches and e-lockers before so how much harder is it to wire and engine?
Old 10-28-2014, 03:12 PM
  #28
4x4YOTA's Avatar
hauled the rest of the 98 donor 4runner off for scrap and budgeted what I had into it...
bought it almost complete but running and wrecked for $300 parted some out for $150 and scraped the rest for $300 so I basicly got paid to take the 3.4 for my swap got to love a good deal
Old 10-28-2014, 04:56 PM
  #29
kornhuskerwizard's Avatar
Nice build!!I dunno much about the 3.4swap wiring,but I'm sure there's tons of info on here.
Old 11-10-2014, 05:27 PM
  #30
4x4YOTA's Avatar
after countless hours and tons of research I finally have my wiring mapped out and ready to proceed
but now I cant find my wire strippers
Old 11-14-2014, 04:09 PM
  #31
sphealy's Avatar
Ever find those strippers?
Old 11-14-2014, 08:38 PM
  #32
4x4YOTA's Avatar
yes I did find them
started soldering the harness adapter tonight
about 90% complete need to lengthen a few wires and attach them to engine components but otherwise its done
Old 11-14-2014, 08:44 PM
  #33
904_runner's Avatar
Good luck with the wiring buddy! I know how that goes
Old 11-16-2014, 10:15 AM
  #34
FK.
FK.'s Avatar
Never had the patience to work on wiring harnesses! Good on you though, hope it works out well
Old 11-25-2014, 08:57 AM
  #35
4x4YOTA's Avatar
Thanks I am hoping it works out as well I have to many hours into research and assembly...
was hoping to have her running by the end of the month but weather has kept me from being able to work in the garage since it is not insulated and the up coming holiday
Old 11-25-2014, 09:06 AM
  #36
JasonYota's Avatar
Subscribed for this build.
Old 11-25-2014, 10:24 AM
  #37
bump530's Avatar
Looking good. Your doing it like I am right now... SAS and motor swap at the same time. And Im doing a rear leaf conversion. Im actually looking forward to the wiring on my 4.3 swap, which I am hoping to start diving into this week.
Old 11-29-2014, 02:27 PM
  #38
4x4YOTA's Avatar
got some more work done on the SAS
also cleaned up the oil pan/sump
found my thrust washers in the pan aswell
Old 11-29-2014, 03:18 PM
  #39
Muskett's Avatar
I really like the idea of trying to keep it low with the solid axle, I am looking foward to seeing how you make it work! Most of the swaps seem like they locate the steering above the springs, will that be an issue with doing it spring under clearance wise? I never looked much into what it takes so I apologize if there is an obvious solution.
Old 11-29-2014, 03:56 PM
  #40
4x4YOTA's Avatar
I'm using stock 84 front springs and doing spring over but the steering will be below the springs because of oil pan clearance issues bit will do spring under with some allpro/TG 4" springs if the steering doesn't work out like I'm hoping
Quick Reply: 4x4yota's 94 SR5 4runner
