4x4yota's 94 SR5 4runner
Old 08-15-2013, 04:28 PM
4x4YOTA's Avatar
bought my 4runner back from my brother since he wasnt happy with it and I am very happy to have it back
specs:
3.0 V6 auto
stock 4.88s
30x9.50x15s on 15x7 white wagon wheels
plans for now are to keep her going and maintain her...
future plans include
3.4 swap w/auto
armor
Lockers
SAS
5.29s? or?
duals behind the auto
winch mount/bumper
31s or 33s
recently did a 1.25" daystar spacer in the rear to level it with the front
before spacer
adding spacer
after spacer
Old 08-21-2013, 07:16 AM
4x4YOTA's Avatar
not much done in work but I have started to collect parts
got a deal on a E-locker w/motor (and a line on another)
84 front solid axle
next week I am going to place an order for my spring hanger and shackle tubes
I am going to use Sky Off Road Designs hanger and Davez Off Road Performance no death wobble shackles
I like there design of Skys hanger for ease of placement and the use of bushing sleeves to make suspension tuning easy rather than fight a M18 bolt through a bushing if I want to swap springs or shackle plate lengths
Old 08-25-2013, 01:50 PM
4x4YOTA's Avatar
got my spring hanger and shackle tubes ordered and picked up a thrid e-locker w/motor if anybody is interested
also debating if I should stay with 4.88s or go to 5.29/5.71s
now need to save up some more and get some longfields and hub gears and call it good
Old 08-26-2013, 04:40 AM
91 4Runner's Avatar
Looking forward to the build....
Old 08-26-2013, 09:01 AM
JonnyBoy's Avatar
Man, if only I'd known an elocker might come available a week ago before I ordered my front housing...how much you want for it? I like your build direction, quite a lot like mine, I think.
Old 08-26-2013, 03:38 PM
4x4YOTA's Avatar
Thanks
my goal is to keep it as low as possible might even do spring under I want it to look like as factory as possible
Old 08-26-2013, 04:21 PM
JonnyBoy's Avatar
Hmm, that would be very interesting to see. I'm not quite trying to keep it that low when I sas, but looking to have it about the height mine currently is with the bj spacers and OME coils in the rear.
Old 08-26-2013, 09:37 PM
4x4YOTA's Avatar
I really like the stance of your 4runner and wouldn't mind if I ended up with a couple inches of lift, but my goal is factory frame height so I could run stock 31s if I wanted to i dont plan any larger than 33s
Old 09-08-2013, 08:17 PM
4x4YOTA's Avatar
spring hanger, shackle tubes, and shackles arrived along with new pitman arm and diff triple drilled flange. just waiting on shackle bushing sleeves from davez offroad and then i should be able to drill the frame for the shackle tubes and then decied where to place the spring hanger...
the sky hanger is way better then TGs and i like to stockish style/look better
Old 09-09-2013, 04:32 PM
Aztecdiver's Avatar
What website did you get that from?
Old 09-10-2013, 02:30 PM
4x4YOTA's Avatar
i ordered it from Poly Performance but it ships directly from SORD but I saved $$ on the hanger and shipping
Old 09-11-2013, 07:50 AM
Gizler00's Avatar
4runner looks way better with the spacer. Im looking forward to seeing this build. I really like the look of the 2nd gen runners. I keep looking for a 4cyl 5-speed one for myself.
Old 09-11-2013, 09:41 AM
4x4YOTA's Avatar
I was hoping for a 4cyl 5speed but couldn't pass up this one up to good of a deal and really clean
also picked up a second set of stock aluminum wheels for her with tires even if they are 235/75/15s
Old 09-17-2013, 08:10 PM
4x4YOTA's Avatar
started drilling my frame tubes got half way thru and burnt up my drill. hope to make more progress tomorrow...
doing it in steps
step 1 drill frame tubes
step 2 measure and position spring hanger
step 3 rebuild front axle
step 4 cut off IFS
step 5 locate and burn in hanger and tubes
step 6 hang springs
step 7 hang axle
step 8 set up steering
step 9 align and finalize
step 10 Enjoy!
Old 09-17-2013, 08:11 PM
4x4YOTA's Avatar
will post pics tomorrow!
Old 09-18-2013, 12:16 PM
4x4YOTA's Avatar
33s on with stock wheels... looks way better
start of the frame tube holes
Old 09-27-2013, 07:54 PM
4x4YOTA's Avatar
so i got the driver side frane tube drilled but got the pass side half way and realized the i need to relocate the tranny oil cooler... anybody got any tips? can i move it anywhere or does it need to be at a certain height or level
Old 10-20-2013, 07:15 PM
4x4YOTA's Avatar
no new progress since the last pics
still need to finish drilling frame tubes but the t-case cooler is holding me up at the moment along with bad weather...
I went to a pull n pay today and scored a hi pinion Diff. Also got a good deal on a brand new in box Aussie locker for the hi pinion. So next is to choose a rear locker and I need to decide on gearing for the hi pinion, either match my rear 4.88 or swap both for 5.29s
Old 05-28-2014, 04:28 PM
4x4YOTA's Avatar
no progress other than collect more parts
Old 06-11-2014, 04:50 PM
4x4YOTA's Avatar
new heart for the 4runner
Quick Reply: 4x4yota's 94 SR5 4runner
