LIVES4CRAWLIN91's 1985 4Runner Build-Up Thread
#82
haha no way! You'd wanna go with the chromo output shafts and 23 splines at least in the rear though...that's a lot of torque on that little output...not to mention that you have to buy two adapter plates $$$$$$$$ lol
Love your 4runner! Man it was pretty when you first bought it lol
#83
and assumin u forgot the names Spencer btw lol... When is the next BCOR meeting?
#84
I FINALLY GOT THE CORRECT TOP SHIFT CASE IN TODAY, so ill finish my front axle this weekend swap out my rear and drop the tranny install the marlin clutch and put the "new" transfer case in and then ill be saving again for the crawl box kit tear my old case down make a crawl box out of it and then time to finish the suspension... although what about triple cases? have a 2.28x 2.28x2.28 slightly lower than a 2.28x4.7 lol or maybe go super crazy and put a double 2.28s and a 4.7 transfer lol thats like 5.2X4.7=24.4 reduction.... AM I CRAZY for considerin 3 cases?
To continue my rant for one more second, if Marlin installed a 3rd 4.7 set instead of the stock box, he'd be at 2828:1. . .
End Rant
Congrats on the getting the Top shift box. I'm going to convert mine when I install the crawl box. . .
Keep us posted with the install of the new box! Good Luck with it!
#85
I've actually got ther 5.29s ... anyways finished stripping my front axle down and when this is all done ill have pics of what was destroyed anyhow, foun out short side birf was toast, not toast as in completly destroyed, but u will see, will be dropping the tranny tonight, and i think im going to go dual stock cases, when i get around to it, and btw i have two gear drive forward shift cases if u know of anyone looking
#86
If you had a second top shift, I would be wantin' to trade you. But I've got two forward shift units.
If I talk to anyone thats lookin, I'll point them in your direction.
Looking forward to the pics. I just rebuilt my rear diff, but didn't get any pics.
#87
got some pics boys oh and i just dropped another 230 bucks.... ordered an axle truss. diff armor and knuckle ball gussets and better than stock birfs... for now. didnt get the tranny dropped... my front axle is main priority ya know. cuz i have become a pro at droppin the tranny and dont think much of doin that, and the rearend swap will happen once ive got the front back in.. ANYWAYS here are a few pics
#88
bracketry cut off and ground down and cleaned up some welding splatter...
I cannot wait to get my drop hanger and build a spring pack or order some tgs... sad my shocks have way more droop than my springs lol
cleaned up knuckles
my "custom" back plates
scuffed up birf from blown lower trunion bearing
see my crack.... glad i caught this now... instead of after rebuilding everything
cleaned up knuckles
#90
I'm waiting on some armor to roll in and my better than stock birfs, but I will def post pics, considering I'll be relearning to weld on the armor so ya . wish me luck
#91
I do have a question... What front kit should i go with. TG 3s or TG 4s? either pack may get a rear main swapped in to give me the added length of a ruf so i have a much better shackle angle and all that. IDK opinions greatly appreciated or and my goal tire size is 37-38s with a 25-27 inch frame heighth. soya input greatly appreciated
#93
na. I wish i could spring for dirty 30s, but then again I have beat the livin piss out of my stock birfs and considers 2 blown wheel seals. 1blown lower trunion bearing and a cracked birf. not bad. so for now im staying 27 splined but trail gears chromo version.
#96
#97
I do love the wider rear end and 1.5 spacers up front it actually helped the COG a ton
#98
I'm running a SuperLift HD 4" lift with seriously sagged fronts, but 2" shackles to level it. At the middle of the Drivers door, I have 24" to the frame, with 35" tires. You'd have to do some serious trimming of the front fenders and possibly tub the firewall to run 37s or 38s. Though you can move the axle further forward to allow better clearance. I've moved mine 1.5" forward so far and the 35s rub a little at full lock. But I also have to mention that's with a welded rear diff, so the body roll in slow turns is SUPER Exaggerated!! lol Especially on pavement and hard surfaces.
#99
Hey guys sorry that its been ages since i last posted. I still havent gotten the my lift finished lol and ya but i did get alot of other stuff on the way to getting finished. here come so much need toy porn lol
beginnings of softop frame
finally got around to tubbin it in lol
finished soft top frame in rustoleum gloss black haha
#100
ill have to take some more pics as soon as i get it back I dropped it off today at an upholestry shop to get the soft top sewn up and all that i just hope it comes out right
