1984' 1uz 5speed 4Runner fiberglass build up
Old 12-15-2015, 11:17 AM
  #41
Gizler00's Avatar
Try using .023 wire on the Lowest setting. You will still have to stitch it to prevent warpage and burn through, but it will be better than the .030.
I have the best luck with that setup when welding this paper thin Toyota metal.
Old 12-15-2015, 11:37 AM
  #42
twasabug's Avatar
Great job. Wanted to do this myself but doesn't look like its gonna happen now. Planning to do it in the future though. Thanks for info and inspiration
Old 12-17-2015, 05:19 PM
  #43
slacker's Avatar
good advice right there ^
Old 01-01-2016, 04:48 PM
  #44
1uzRunner's Avatar
Got some help from friends and got things moved around for the next part of the buildup!
Old 01-18-2016, 02:43 PM
  #45
thasnake04's Avatar
got any updates
Old 02-14-2016, 07:15 AM
  #46
1uzRunner's Avatar
Sorry about the media blackout...
Had to have mini me pull some strings to get progress started again!
He tried his best but just couldn't make it happen.
Finally he decided best way to get things done was to jump in and do it himself!
Old 02-14-2016, 08:06 AM
  #47
1uzRunner's Avatar
Been hording parts last few months...
Parts ordered:
36x12.5x15 Swamper SX x4👍
1uz-fe R150 adaptor/clutch/flywheel👍
ORI STX 12" Struts x2 ☁️👍
Marlin Crawler:💪
R150 series: HD first gear thrust bearing, cnc bearing cover plate.👀💪
RF1A Transfercase:💪
HD rear output, transfercase seal kit, Shifter bushing, HD T-case shift rail spring
Picked up a parts washer.
Tranny transfercase build:
Transfercase:
Tranny/T-case:
Old 02-14-2016, 03:08 PM
  #48
bootscootboogie's Avatar
Man that parts cleaner is dope
Old 02-16-2016, 12:46 PM
  #49
Staff
kawazx636's Avatar
Have you even rebuilt a tranny or t-case before? I was just wondering how easy it was to do and how much expertise/prior experience you have? I want to rebuild mine and I am obviously very in-tune to everything automotive, but transmissions kind of scare me a bit. Words of advice or encouragement?
Old 02-16-2016, 01:07 PM
  #50
1uzRunner's Avatar
I guess I started out on dirtbike engine/trannys and then lawnmower trannys to get the driveway plowed. Even built a hybrid aw4 for the ol ladys 99' cherokee. As long as you have the service manual follow it. If the vehicle is not your only transportation so it can be down if parts need ordering, then I would not be affraid. Need to have the right tools and that includes a press and pullers, torque wrench, feeler gauges, micrometer, and some other tools that should be listed in the manual.
Old 02-17-2016, 06:33 AM
  #51
amalik's Avatar
I figured with your build thread, there's nothing you haven't done
Sick truck, btw.
Old 02-18-2016, 08:33 AM
  #52
Staff
kawazx636's Avatar
Thanks for the advice. I've just never had to tear into one, but I have heard horror stories from those that have but should not have. I might give it a shot.
Sick truck, btw.
The tranny and t-case are the only two things I didn't touch on my truck. I have the more rare L52 tranny so I have been afraid of screwing it up or not having replacement parts available.
Old 02-19-2016, 11:16 AM
  #53
1uzRunner's Avatar
Got some more parts!
36x12.5x15 SX!
ORI STX 12" Struts!
Damn it feels good to be an offroad Gangster!
Old 02-22-2016, 08:55 AM
  #54
1uzRunner's Avatar
Transfaercase done!🤖Name:  image_zpsvlhbyjkw.jpeg
Had to do the front output as well while it was apart.
Tranny is finished as well but it was late 😴
More pics tonight!
R151f Adapter showed up at the house. Hope it's legit!👍
Old 02-22-2016, 12:49 PM
  #55
Staff
kawazx636's Avatar
Nice! Maybe you can stop by and rebuild my tranny for me... I have lots of beer!!!
Old 02-22-2016, 04:39 PM
  #56
slacker's Avatar
looking great !!
Old 04-23-2016, 04:59 PM
  #57
1uzRunner's Avatar
Old 04-23-2016, 05:01 PM
  #58
1uzRunner's Avatar
Found a sweet Australian made aluminum rear sump!!
Old 04-23-2016, 05:06 PM
  #59
1uzRunner's Avatar
Also exhaust flanges!
Old 05-11-2016, 07:04 PM
  #60
txlonghorn's Avatar
Man you're making good work! Jealous of the patience you've put into doing the body work. Those ORX look awesome.
Quick Reply: 1984' 1uz 5speed 4Runner fiberglass build up
