1984' 1uz 5speed 4Runner fiberglass build up
3 Attachment(s)
My 4Runner has been a good truck! I bought it with a 3" lift. It had tube bumpers and a knocking engine. I put a 22r I had laying around in it and sucked in some water. So then I bought a 83' celica EFI 22re and harness/ECU. That really woke the truck up and made it a lot more controlable offroad and gave me a much better miles per gallon. Found a parts truck, scored the double transfercase with 4.7 gearset in one and 2.28 in the other. E-locker for the front, detroit locker rear, cross over steering, longfields, rear disc brakes and a bud built crossmember. I put the grill and headlights off my first toyota truck, it was a 1980'. Finished that all up last winter/spring.
Decided I want to do a Bit more... So at the begining of the year, I knew I had some tax money coming back. So I pulled the trigger on a set of Hi-Clearance fiberglass quarter panels, door skins, tailgate skin, front fenders, L brackets on the topper, and the rear inner panels. Then I started looking into more power. 1uzfe was the answer I settled on. Now I own 2 engines 2 ecus and one and a half wire harnesses and an auto tranny for one. One is 135k miles with fresh waterpump/timing. Other is 152k miles with the same fresh parts. Both from 92' SC400. So the 22re was sold. Still figuring out parts. Front fenders were chucked, doors removed, top off, interior stripped for rollcage and no motor, it sits on 35x15.5 swamper SX on 32 bolt beadlock rims waiting for build time! The rear tire came loose at 65 mph! -junk aluminum rims Attachment 118912 Attachment 118913 Attachment 118914 More soon! |
7 Attachment(s)
Got the motor testfit!
Attachment 118082 Attachment 118083 Then 3 days early, Fiberglass Arrived!!! Attachment 118084 Attachment 118085 Attachment 118086 Attachment 118087 Attachment 118088 1 week of work then I took a week off to hopefully get these panels attached! I want to lower the truck 4" now. Blown away happy with my fiberglass! |
dude this is a SICK build already. I love the first gen grill and roundies. Looking forward to seeing more of this!
Build week!
Its my week off so this bad boy is going to get completely blasted and prepd for new metal and the fiberglass. Buying up a couple rolls of poly to build the second garage into a paint booth! Still have not settled on a color but I figure worry about the body work first and by then I'll have a better Idea of the color.
Also picking up the tube bender from work to build some rock rails, and maybe a rear bumper. Need to pickup more steel for the cage, more sheet metal for wheelhouses and custom front inner fenders. Its Awn!!! Pics and progress soon! |
2 Attachment(s)
A frame up!
Passengerside rear off! Second airtank connected for blasting! Attachment 117923 Attachment 117924 More tonight! |
uh..... OM MY GOD!
Nice work! How do the rear quarters attach, rivets or some sort of automotive adhesive? Look forward to seeing the end result!
3m 08115 panel bonder for the quarters, door skins and tailgate skin!
Going to be blasting the rest today, then start replacing metal tomorrow! Needs body mounts so after most of the body is repaired, body is coming off for a full enderbody blast and a coat of Por 15! Bottom 10" of all body will be with Por 15. Sure its going to weigh a bit more but... This truck will live a long time! |
4 Attachment(s)
Before:
Attachment 117904 After: Attachment 117905 Tailgate hinges: Attachment 117906 Attachment 117907 |
3 Attachment(s)
Side badges are hard to read...
Attachment 117890 Sandblasters are awesome! Attachment 117891 Attachment 117892 |
Tailgate
5 Attachment(s)
Tailgate time!
Heres a preteardown shot. Attachment 117885 Grind the edges till they pop! Bam! Attachment 117886 Little rusty inside... Not Por long! Hah! Attachment 117887 Attachment 117888 Attachment 117889 No blasting tonight so I'll pickup in the AM on more blasting dutys! |
3 Attachment(s)
Heres a couple of my night time project that went into today...
Attachment 117838 Attachment 117839 Attachment 117840 |
Marlin has body mounts on backorder so I am going to wait on that action for a bit. They say a week or so.
Everything I blasted yesterday needs a quick touchup again today since it got rained on just a sprinkle or two... I keep looking at it thinking its way too high, even with the V8 in it. After the testfit with the new body, I want to lower the truck 4" while keeping a flat bottom center. Thats not going to be easy and I will have to build a custom oilpan but I believe it will be will well worth it!! While all this is going on I am also planning to use a set of rubicon express front Longarms and either airshocks or coilovers. I really liked what they did for my old XJRubicon. I'll have to take some measurements and see if I can make it work before I pull the trigger on that one though. Off to the store for supplies! |
This thing is gonna be sweet!
cool Pat ... looking good so far :)
6 Attachment(s)
Found a pic of the day I bought it!
Attachment 117755 On with the build! Picked up a quart and a pint of: Attachment 117756 2 coats in the doors! Attachment 117757 Quarters: Attachment 117758 Attachment 117759 Had to retire the old junk wire feed. Picked up a Millermatic 211! Attachment 117760 Now we can start getting serious! Didn't get the quarter panels on like I planned but I am a lot closer. Got a lot of the puzzle pieces in place this week. Getting the new welder was one of the huge things holding up the Body and Cage work. Going to be chopping off the front clip and building new. Front bumper ties in with the rollcage and through to the back. This build will be finished before the end of March. |
that looks good man. I like that you're flaring the wheel wells hard... and hopefully tubing the front.... get low bro get low!
https://cimg0.ibsrv.net/gimg/www.yot...c1cca21cc3.jpg This dude from canada is rockin' 35" on his 02' Taco with zero lift... I'm glad that you're cognizant of your goal end height. |
watching this! interested in the 1UZ swap, I have a 86 xtra cab with bad 22RE!
Nice! I'm along for the ride on this one!
2 Attachment(s)
