Wulfdan's 82 Hilux SR5 Build Thread
Old 05-13-2014, 02:48 PM
  #61
HighLux's Avatar
Originally Posted by Wulfdan
header and cam will both be done as well as a stroker crank so if I want a real weber carb, it would be silly to get the 32/36 when I'm going to need the bigger one sooner or later. This isn't a DD so gas mileage isn't as much of a concern. The "fake" will stay put until I get the cam and header installed most likely, b/c it runs fine.
A used weber or weber clone will sell like a hotcake too.
Old 05-13-2014, 03:43 PM
  #62
83 trail rig's Avatar
Originally Posted by HighLux
yes the one in the link is fake weber carbs direct is the chinese copier of the weber. they are turds. Just cause they call themselves weber carbs direct does not mean they are Real weber carbs. Real weber carbs are made in spain. THey have the white choke housing. If you have the one with a black housing...you have been fooled into buying a cheap reproduction. This is a real weber.... Video Link: http://www.ebay.com/itm/Toyota-Pickup-20R-22R-Weber-Carburetor-Conversion-Kit-/331189781899?pt=Motors_Car_Truck_Parts_Accessories &fits=Make%3AToyota%7CModel%3APickup&hash=item4d1c 73058b&vxp=mtr
dam all these years I've been doopped I've been ordering webers for 25+ years and didn't know about exact fakes from weber I do know china makes everything but these carbs I buy come from Italy and have the correct copyright marks
But I will check on it
Old 05-13-2014, 03:53 PM
  #63
Ok I checked it out fake is not the word when a copyright runs out china makes them USA makes them Spain makes them and Italy
Italian weber are the original and Spain is the newest factory if they have a weber W or the name weber on the casting they came from a weber plant USA says made for weber in USA and the china ones just have a weber sticker
You had me mad and sweating cause 520 plus change is to much for a copy
Old 05-13-2014, 03:58 PM
  #64
HighLux's Avatar
You paid 520? ouch.
Old 05-13-2014, 04:08 PM
  #65
HighLux's Avatar
Dallas huh? Hmmm... keep an eye out for a first gen cab if you can. Looking for one from a rust fre zone. Dont care about surface rust. But I'd roll to Texas to pickup a cab or a roller with a clean cab on it. Mind keeping an eye out for me?
  #66
They are not as pricey as the Ida's or even the idf's for that matter they used to be around 400 for a set without manifolds now your lookin at 1200 from weber no manifolds and of course no linkage which I'm so happy that this set up came with
Of I had known about copies I might have gone that way I just looked them up and you can get one for around 250
Even having to smooth out castings and do jet work it might be worth it
Old 05-13-2014, 04:10 PM
  #67
firstgenlife22r's Avatar
About to start my own build soon. Got a 80. This helped alot! Thanks
Old 05-13-2014, 04:11 PM
  #68
HighLux's Avatar
I paid around 250 for my real weber. Im not saying those carbs are completely useless...there is always a loss in quality and performance when the Chinese knock something off. And as far as I can recall...there are no carbs at all made in america anymore. Spanish weber...or chinese copy. Only ones on market. Even if it says USA...a Chinese person probably cast that...lol.
Old 05-13-2014, 04:20 PM
  #69
Also wish I'd of known about Spanish one being 250 that's a steal for anything with the weber name on it
You should make that known on here
Old 05-13-2014, 06:54 PM
  #70
HighLux's Avatar
You may be the only one that doesnt...lol.
Old 05-14-2014, 04:29 AM
  #71
Wulfdan's Avatar
I found an 88 2WD frame for $200. It has the long bed like my truck. Would this work to replace the frame on my 82' 4x4 SR5? The guy also wants to sell the bed, which is in good shape.
Old 05-14-2014, 06:14 AM
  #72
haha yea my old ass is out of the loop
Old 05-14-2014, 06:16 AM
  #73
thats not a direct fit
I believe it's wider I might be wrong
It's defiantly an ifs
Cab mounts are in different spots
Old 05-14-2014, 07:35 AM
  #74
Wulfdan's Avatar
Ah, scratch that then. I'll reweld everything and box it with new steel. Think that will work?
Old 05-14-2014, 08:02 AM
  #75
Staff
kawazx636's Avatar
Given the location and extent of your frame damage, I would keep looking for a good frame. If you consider the amount of time, materials and money you would spend on bringing your frame back to a safe standard you'll quickly see that you are better off finding another one. Frames are out there, just have to find one.
I just did a quick search on Car-part.com (Junk yard search site) and there are a handful of shortbed frames (I'm assuming you have a shortbed) all around you in GA, SC, TN and NC. Scope out the site. I haven't had much luck since there are very few junk yards around my way, but it could be a good resource for you.
Old 05-14-2014, 09:05 AM
  #76
Kawa is so rite on this
And trust me as bad as you'd looks just keep looking and storing parts for it
Old 05-14-2014, 09:22 AM
  #77
Staff
kawazx636's Avatar
I also failed to mention, that you haven't even found all the damage yet. I'm certain that you'll end up finding more rust issues as you are fixing what you already know about. Plus, it's not exactly easy or effective to weld to old, thin, rusty metal.
Old 05-15-2014, 06:12 AM
  #78
Wulfdan's Avatar
SR5 Longbed. I'll look at the site.
Old 05-15-2014, 06:14 AM
  #79
Wulfdan's Avatar
The plan I had in my mind was to go up the frame from the rusted out part until I found good metal and either box to reinforce, or cut the bad section out and weld in good metal. Too much hassle?
Old 05-15-2014, 06:21 AM
  #80
Took me 2' on both sides to find good metal or weld able at least so now I'm adding 4xinovations full 4runner cage in my 83 with 6 frame tie ins I should be fine
When I should have spent the time effort and money on a good platform
Quick Reply: Wulfdan's 82 Hilux SR5 Build Thread
