RustyToy's $100 83 4x4 longbed Rebuild Thread
Old 01-04-2011, 08:28 AM
RustyToy's Avatar
last year at my family christmas i finally asked my uncle about that toyota that has been sitting in his yard since 02. he said it doesnt run and he would sell it to me for $100 so i rented a tow dolly and picked it up. it had two flats and i only had one spare. so i put the spare in the rear and left the flat in the front on the dolly. well halfway home the trailer started swaying violently over 40mph so i pulled over and one strap was completely off and the other was barely holding on to the flat tire. It was a close call but i finally arrived home
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0569-small-.jpg
Old 01-04-2011, 08:30 AM
little_93_pickup's Avatar
nice find
Old 01-04-2011, 08:36 AM
mightymouse's Avatar
and then.......
xxxtreme22r's Avatar
now why can I not find deals like that?
Old 01-04-2011, 08:53 AM
RustyToy's Avatar
after taking the truck apart i found mud everywhere.
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0584-small-.jpg   RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0597-small-.jpg
Old 01-04-2011, 09:03 AM
RustyToy's Avatar
other than bed rust this was my only problem. from the bottom right corner of the window seal leak. anybody have pics of fixing this?
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0588-small-.jpg
Old 01-04-2011, 09:13 AM
Fossilized
Staff
dropzone's Avatar
Pretty common issue with regard to the floor rust, my had it three out of the 4 cab corners.
chip out the sound deadening material (it likes to catch fire), grind out the rust so you have a clean area to weld to and cut a patch panel to weld in the there
Old 01-04-2011, 09:52 AM
Swimmerboy2112's Avatar
x2 man...
Old 01-04-2011, 12:07 PM
Originally Posted by Swimmerboy2112
x2 man...
x3. wish i could find something like this.
Old 01-04-2011, 12:49 PM
cztheman64's Avatar
he wouldnt happen to have another truck in his yard does he? im callin first dibs
Old 01-06-2011, 08:28 AM
RustyToy's Avatar
most comfortable truck bed ever!
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0582-small-.jpg
Old 01-06-2011, 08:33 AM
RustyToy's Avatar
the truck had a 2wd oil pan on it and i think someone had jumped the truck because it had an imprint of the axle housing in it. so i took it off and the oil pickup was bent and i found pieces of plastic from the timing chain guide in the pan.
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0611-small-.jpg
Old 01-06-2011, 08:39 AM
RustyToy's Avatar
so i used my forklift at work to remove the engine and found a mechanic who already had a rebuilt motor and used my broken one as a core charge and had him put the new one in.
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0658-small-.jpg
Old 01-15-2011, 05:05 AM
DrifterTim's Avatar
love the mattress bed lol but if it snows or rains its a cold wet bed
Old 02-01-2011, 08:36 AM
RustyToy's Avatar
new engine with my new Weber 32/36 carb.
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-img_0668-small-custom-custom-.jpg
Old 02-01-2011, 07:29 PM
redsyota's Avatar
great build, keep the updates and pics coming!!
Old 02-03-2011, 08:54 AM
RustyToy's Avatar
finished my two coats of primer on the body.now started spraying the frame and suspension.
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-framepaint-small-.jpg
Old 02-03-2011, 08:55 AM
RustyToy's Avatar
started putting my coats of flat black on the truck. sorry blurry picture.
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-paintblack-small-.jpg
Old 02-03-2011, 09:06 AM
RustyToy's Avatar
i used the electrolysis method to clean my gas tank. then i sealed it with a quart of POR-15. and painted the outside with the undercarriage spray.
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-gas-tank-small-.jpg
Old 02-03-2011, 09:11 AM
RustyToy's Avatar
my 3" skyjacker lift and shocks came in and i also found a good deal on a set of used 17" rims off craigslist!
Attached Thumbnails RustyToy's 0 83 4x4 longbed Rebuild Thread-rims-small-.jpg
Quick Reply: RustyToy's $100 83 4x4 longbed Rebuild Thread
