Total Chaos IFS brace - truss - brand new
SOLD!
$37 shipped/$30 local pick up. Never used. For '86-'95 4Runners or Trucks.
This truss was designed to allow the removal of the front differential after installation.
If you off road, the A-arm sub-frame connecting the lower arms takes a beating. Over time, the unbraced rear mounts for these arms tends to pull apart, degrading alignment and weakening the front assembly. A few beads from the welder combined with this truss and the problem is solved. This builds a truss behind the front differential to prevent the back of the lower mounts from separating.
oops i shoulda mentioned that. I did lower it from the original post. I paid $44~ so either way you win a little, i loose a little.
A local member said he wants it but if it ends up not fitting his truck then i'll let you know.
justdifferentials
14
06-11-2017 08:36 PM
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
09-09-2015 02:43 PM
