FS: set of Rancho 9000x's and Stock radio/CD
FS: set of Rancho 9000x's **REDUCED** $100+S&H
Ok, I got a full, new OME suspension thanks to the guys from trdparts4u.com (thx Gumbo and Strap22) and I have no need or my Rancho 9000X shocks that were on the truck.
These all have a lifetime warranty for purchaser and/or INSTALLED ON ORIGINAL VEHICLE.
One shock was bad when I had the new ones installed. I called Rancho Customer Service and was told that any retail location that sells Rancho would accept the bad shock and give me a new one for no charge. I did exactly that so we have 1 brand new front shock and 3 used, warranted shocks for a stock 2nd Gen 4Runner.
Front shock part no. RS 99145 (2 shocks)and rear part no.RS99187 (2 shocks). These will come with a photocopy of my receipt which was not needed when I received the new shock from 4WP. Technically you could have new shocks for life.
I went with the OME as I added the rear coils and there wasnt enough full extended length to work with a lifted rear.
*NOTE: Stock 2nd Gen. 4Runners is what these will work on.*
$320 new for a set of 4, I paid $219 + shipping, and I'm selling for $125 + actual s&h to you.
**REDUCED** $100 + actual shipping to you.
I prefer Paypal. photomike72@yahoo.com
check my Ebay feedback under megibson. Over 105 listings with 100% feedback.
Thanks!
Mike
Thanks!
Mike
philpayne,
check out the application guide at Rancho's website:
http://www.gorancho.com/products/applications.stm
go under shocks and look for your truck model on or about page 41 of the pdf.
It appears that the fronts (#99145) will work on the 4WD trucks and it calls for #99180 on the rears for trucks and these are #99187. I dont know why they wouldnt work for stock height, but maybe call Rancho tech help (734-384-7804) and see what the differnce is between the 2 models. I'll call to check as well. They were installed on a stock height 1994 4Runner SR5 4WD.
I'll get back to you as soon as I can with the info.
*Well, I checked out the spec sheet and it appears that the difference between the shocks is mounting points. The 99180's have a bushing mount on the upper and lower and the 99187 has a 3/8" stem upper and a bushing mount lower. Can you verify that the rear shocks on your truck are bushing mount upper and lower?*
Cheers,
Mike
Cheers,
Mike
the1998sr5
15
07-14-2020 08:35 PM
crashburnoveride
07-10-2015 06:39 AM
