FS: 3VZE Engine parts, A340H Trans/Tcase, 2000 Limited Tcase, and more.
Old 03-29-2006, 05:16 PM
Cebby's Avatar
12-13-06
Finally everything in one place!!
Check the link in my sig - I now have all the remaining items on my new website. There are other items that are not listed yet too, so just ask if you don't see something. I will put a list together of what is definitely gone in the next day or two.
http://4r.corequipment.com (click the parts for sale link)
I will not be updating the pics/removing items sold from this thread anymore.
Pics to follow - shipping (and packaging for the heavy stuff) is in addition to pricing listed:
[*]1993 3VZE R12 Air Conditioning Compressor - $ 75
In working order when removed. Could be used for OBA - see Pirate4x4.com for details.
Note: Grease on the case of the AC pump is from the leakng power steering pump.
[*]1993 3VZE Alternator - Stock - $ 60
PIC TO FOLLOW.
[*]1993 3VZE Power steering Pump - $ 40
In working order when removed. Leaks some - could use new seals.
[*]1993 3VZE Engine Driven Fan complete with working clutch - $ 35
PIC TO FOLLOW.
[*]3VZE Aftermarket replacement radiator - $ 85
No leaks, but upper brackets need to be brazed back on.
[*]2000 4Runner Limited Transfercase - $ 250
Had to buy for the trans I'm using. Never used by me, but item was tested by the yard I got it from along with the trans. Item has 67,000 miles on it.
PIC TO FOLLOW.
[*]1993 2nd Gen 4Runner Stock Crossmember - $ 40
A little rusty, but not dented or tweaked.
PIC TO FOLLOW.
[*]*JUST ADDED*1993 2nd Gen 4Runner Stock Skid - $ 40
[/list]
Paypal or Money Order only. Shipping additional.
PRICES NEGOTIABLE. MAKE OFFERS, I NEED THIS STUFF GONE.
SEE MY OTHER SALES IN THE MISC SECTION (links in sig)
Cebby is offline
Old 03-31-2006, 12:48 PM
snap-on's Avatar
PM sent
snap-on is offline
Old 03-31-2006, 03:02 PM
Cebby's Avatar
Updated the list - some items pending.
Cebby is offline
Old 04-06-2006, 05:28 PM
Cebby's Avatar
Some items sold, list updated.
Cebby is offline
Old 04-11-2006, 05:53 PM
dmatter's Avatar
You Know it is a Toyota Part when it ONLY has 140,000 on it
dmatter is offline
Old 04-12-2006, 06:15 PM
Cebby's Avatar
Here's pics of the Mr. alt that have been asked for:
Here it is when it was new...
Here it is as it sits now (on the engine - on a pallet )
Cebby is offline
Old 04-21-2006, 12:03 PM
Cebby's Avatar
Deleted sold items, some more items pending and added a few new items.
Cebby is offline
Old 05-09-2006, 10:40 AM
Cebby's Avatar
BTT - Prices reduced - I need this stuff out of here...
Cebby is offline
Old 05-18-2006, 07:50 AM
taikowaza's Avatar
hi cebby-
interested in your a/c compressor and AFM and skidplate, maybe more
can you also sell your HVAC fan switch? (mine is stuck in LO)
thanks
taikowaza is offline
Old 05-18-2006, 09:35 AM
Cebby's Avatar
Originally Posted by taikowaza
hi cebby-
thanks
Still have the parts you need.
Do you mean the HVAC fan speed control from the interior? If that's what you mean, I'll still be using mine. (only parting out the stuff not being reused from my engine swap). If you can't find one near you, I know of a few yards I can dig one up for you. You probably need more than just the switch though from the sounds of it.
Oh - what's your zip so i can check shipping for you?
Cebby is offline
Old 05-19-2006, 10:59 AM
Cebby's Avatar
Lot's of pics added to the first post.
Cebby is offline
Old 05-20-2006, 10:45 AM
mt_goat's Avatar
Didn't your radiator have a lifetime warrany? You could exchange it for a new one and then sell it. Where did you get it?
mt_goat is offline
Old 05-20-2006, 12:36 PM
Cebby's Avatar
A local joint that went out of business due to a flood...
I may end up using it anyway in which case I'd fix it - hell I might fix it anyway. Been a while since I brazed though...
Cebby is offline
Old 06-09-2006, 09:48 AM
Cebby's Avatar
3VZE Engine Dismantling - Get in line!
I've decided to part out my 3VZ (3.0 V6) engine from my 93 4Runner. There has been some interest in it as a whole unit, but nothing has materialized and I need this thing outta here. It had sprung an external coolant leak at the rear of the driver side head - immediately shut down.
Unless someone needs something more specific, I was planning to part it out as follows:
heads - $100 each or $175 for both
block - $150 (bare)
crank - $100
rods - $100 (set of 6)
upper intake - $40
lower intake - $40
throttle body - $100
knock sensor - $40
Any other parts can be discussed. Prices to be added, but will consider any reasonable offer.
Those that have PM'd me in the past for parts will have first dibs - I will be checking with each of you first.
All prices are for part only - shipping additional.
More stuff here: https://www.yotatech.com/forums/showthread.php?t=82282
(I'll combine the threads eventually)
Cebby is offline
Old 06-13-2006, 10:59 AM
Cebby's Avatar
Prices added.
Cebby is offline
Old 06-13-2006, 08:21 PM
rocket's Avatar
Cebby, i posted my 3.0 engine (complete and still in the truck) on Craigslist and had 2 phone calls within 45 minutes! I then had another 5 calls over the next 24 hours. Every single caller wanted to buy it. A couple guys even offered me 3 times the amount that i was asking but unfortunately i sold it to the first guy. There are tons of people out there wanting a complete 3.0 engine and it seems there all looking on Craigslist.
rocket is offline
Old 06-13-2006, 08:34 PM
Cebby's Avatar
Hey Rocket - thanks for the info - I haven't dismantled it yet, so I guess I'll try Craigslist first. I'd prefer to move it in one piece if possible.
Cebby is offline
Old 06-16-2006, 08:04 AM
axon's Avatar
Cebby,
How much for the whole thing and what are the issues with it?
axon is offline
Old 06-16-2006, 09:17 AM
Cebby's Avatar
External leak on the head gasket at the driverside rear of the engine. It was immediately shutdown when it started leaking. When I drained the fluids, the oil and coolant had not mixed.
Engine was strong (for a 3.0) prior to the problem. Has around 140k miles. Had the HG replaced under the recall at 60k IIRC.
$400 for the whole engine + shippping. Engine is in zip 15139 currently (out of 4Runner on a pallet)
Cebby is offline
Old 06-28-2006, 07:08 PM
thefallman's Avatar
cebby have you sold this engine yet?
thefallman is offline
Quick Reply: FS: 3VZE Engine parts, A340H Trans/Tcase, 2000 Limited Tcase, and more.
