85 SAS runner w/88 pu cab for sale
http://i10.photobucket.com/albums/a1...7/MVC-001F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-002F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-003F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-005F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-004F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-008F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-009F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-007F.jpg
http://i10.photobucket.com/albums/a1...7/MVC-006F.jpg
This truck is a 1985 4runner rolling chassis with a 1988 toyota pickup cab instead. The truck has the 85' straight axle front suspension, 22RE EFI 4cylinder.Just did the valve tappet adjustment to factory specs. Has 33X12.50X15 tires with decent tread. The truck used to be an automatic, but i switched over to a 5speed. Here's a list of parts. Skyjacker 4 inch spring lift, explorer procomp nitro shocks, new front sterring stabilizer, new fuel filter, new NGK plugs and wires. new front rotors and pads, new rear drums and shoes. totally new ebrake system(all cables replaced with toyota factory parts), new exhaust, stainless steel headers, heat wrapped headers, new O2 sensor, energy suspension bushings and body mounts, new belts, all new hoses, new radiator, homemade watertight snorkel intake, BN 800cca battery, new starter, new altenator, newair filter, front brush guard, rear homade rectangle stock bed(needs to be finished), welded frame crossmember with a 2 inch reciever welded in, converted from an automatic to a 5speed, new flywheel, new clutch, new clutch slave cylinder, new brake lines, tranny and transfer case have been flushed and refilled with synthetic gear oil, coolant flushed and filled, power steering, new CB radio. This was my project truck for 2 years now but a baby is on the way and im forced to sell it.the truck needs some minor TLC. the rear end needs a pinion bearing and seal. I also have a spare axle and the automatic transmission that came out of it. I also have all the reciepts for everything. I hope this truck goes to a good home and somebody who will appreciate this truck. I'm askin $1700 B/O. thank you for the interest. I also have many more pics of the truck so email me if interested. My phone # is 518-701-5527cell and home is 518-283-1770
6th Gear
19
12-10-2019 07:31 AM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
09-22-2015 07:25 PM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
