zero offset wheels?
zero offset wheels?
i did a search but didn't find my answer... Does anyone know if i can run a zero offset rim? 15x6 6x 139.7 bolt pattern 4 1/4" bore +0 offset
ive got a 2nd generation pickup sr5. the offset i have on the stock rims appears to be about 2" ? i think?
so anyone know if a zero offset rim will fit?
i'd like to get the wheel/tire inside the fender well a little bit and i found some cool rims w/ zero offset.
How will they fit better?
the zero offset wheel will stick out farther, right? in other words stock wheels fit inside the well more?
Maybe the wheels you have are not stock. Stock backspacing on the IFS wheels is about 4-3/4"
On a 7" wide rim, this is 1-1/4" offset from center (never can remember which sign goes which way on offset - that's why I prefer backspacing, it makes more sense for fitting wheels to vehicles). In any even, that manes a 0 offset 7" wide wheel would stick out 1-1/4" wider than the stock wheel.
Up&Down
08-05-2015 06:20 AM
skoti89
07-06-2015 07:45 PM
