Trxus MTs 33" vs 34"
Old 03-07-2007, 02:11 PM
89red4x4yota's Avatar
ok so this summer i will be buying new tires but i have a question about the trxus m/t...i the positives of having 35's but don't want to go that big, and 33's are what im looking for , but the trxus comes in 34" would i feel the difference from the 33" and how much slower would the 34" be without regearing compared to the 33's. also does anyone know where i can get exact sizes on these tires....thanks guys
Old 03-07-2007, 02:12 PM
alos anybody running these tires i would like to see pics of them on your rig, the online pics don't do any justice
Old 03-07-2007, 02:14 PM
wjwerdna's Avatar
http://www.4wheelparts.com/PPT3870T100019.aspx has exact inch diameters, along with the manufacturers website for sure
Old 03-07-2007, 04:05 PM
lee
lee's Avatar
https://www.yotatech.com/forums/f2/new-meats-pics-100556/
i have 33x12.5x16s
i LOVE them
Old 03-07-2007, 04:58 PM
tc
tc's Avatar
Go with the 255/85-16 - right in between at 33.3" OD
Old 03-07-2007, 05:29 PM
i would tc but i have 15 inch rims
Old 03-08-2007, 06:40 AM
lee, i love the way those look on your rig, anyone else run these, is it really worth dishing out the extra $30 per tire for the 34" will it make much difference then a 33" tire on the trail?
Old 03-08-2007, 06:41 AM
also lee what do your 33's measure out to exactly....33"?
Old 03-08-2007, 07:33 AM
lee
lee's Avatar
the 34 probably wont make much of a difference but if you can fit 34s, i dont see why you wouldnt?
ive never measured them
Old 03-08-2007, 12:00 PM
the reason i am shying away from the 34's is because they are $40 more for each tire, and i don't think, for that much money i would see a big difference offroad or ground clearance. the 34's are an extra $160, my question is are they going to be worth the extra money aving offroad?
Old 03-09-2007, 12:43 PM
lee
lee's Avatar
if you cant clear them really well id say no
ground clearance via tires is sorta BS anyway. what you care about is contact patch and flexibility.
if you can stuff them well and your rub doesnt inhibit flex, then you should be ok with a 34... but for the price id go with the 33s.
Old 03-09-2007, 04:34 PM
tc
tc's Avatar
Originally Posted by lee
iground clearance via tires is sorta BS anyway. what you care about is contact patch and flexibility.
Huh? This is perhaps the biggest load of BS I've ever seen on a Toyota forum.
The ONLY way to increase TRUE ground clearance (under the diff, which is the lowest spot) is bigger diameter tires. (Well, OK - you could switch to Portal axles, but that's not practical for most people) You should ALWAYS run the tallest tires possible, which usually means a narrower tire. The difference in traction on MOST surfaces (sand and some mud being the exception) is negligible compared to the ground clearance benefits. In addition, a LONGER contact patch (as a result of a taller tire) generally does more for you than a wider contact patch.
Here's a paper that explains it more scientifically:
http://www.expeditionswest.com/resea...tion_rev1.html
Old 03-11-2007, 07:06 PM
lee
lee's Avatar
dude the difference in ground clearance BETWEEN A 33 AND 34 is pretty negligible, thats all i meant.
its especially unhelpful if he cant flex them.
Old 03-11-2007, 09:02 PM
Nitro Hotpants's Avatar
35x12.5 R15's on my 3rd gen. Haven't had them 4wheeling yet, but I'm sure they'll do just fine.
06-01-2021 01:51 PM
he's gone
7
12-03-2019 07:08 AM
Jcrawl94
10
10-24-2015 04:34 PM
Mr. Bob
28
01-07-2006 03:23 PM
Mr. Bob
01-07-2006 11:47 AM
Quick Reply: Trxus MTs 33" vs 34"
