Post tire and fender pics
Hey all, I'm really itching to buy new pro comp steelies and did some research. It seems the masses go with the 3.75" backspacing. At first I'll just be running 31x10.5r15 with a 15x8 wheel. These basic ones here:
but obviously they'd be 6x5.5 lug pattern.
So I went out to the truck to measure my current backspacing and discoverd my wheels arent even the same front to back. wtf? Front sticks out more by at least an inch.
You can see how much more it sticks out up front.
Well anyways, I was just seeing if anyone wanted to post pics of there setup. I want to see what a 15x8 rim with 31x10.5 looks like with 3.75" BS from the side so I can view how much it sticks out. Google image search failed me and I can't get a good enough visual with my tape measure.
ima hopen im doing this rite i have an 81 yota 35 12.50 15 an thy stick out about agood 3.5 mabe more frm under the truck
CBO - from the pics of your rig, you have the same wheels F/R, so all your backspacing should be the same. You do have a different bed on the rear of the truck, so that's likely why you're seeing a difference in tire exposure.
I'm not running 31s, but this will give you an idea. truck is 93 with 33x12.5 Toyo's on 15x8-3.75" alloys. I'm guessing you'll be maybe 3/4-1" closer to fender with a 31 on this size wheel.
outside fender shot:
clearance to upper control arm - JUST enough room with my 12.5 wide Toyo's, which are slightly wider than other brands due to sidewall lugs:
I tried Google Translate with no success
09-04-2015 09:27 AM
jon.r
07-11-2015 03:34 PM
