how big of a tire will fit in the back
hey, i was thinking about buying bigger tires for the back of my truck and keeping my 31's in the front.
i was wondering if i can fit 33x10.50's in the back. if not could i run 32's?
i drive a 1989 Toyota pickup reg cab. i have a 2" shackle lift in the back but my springs are sagging pretty bad, so it sits at the stock height i'd say.
Wait, you want to run 33's in the back and 31's in the front? Why?
Will they fit? Sure - but you'll never be able to use 4WD like that since effectively the gear ratios will be different at each axle.
i thought it would be cool, but now that you said that, your right it will never work. thats too bad. would 32x11.50's mud tires fit on the front and back?
for god sakes man, do a search!!!!!!! It is discussed with a new thread at least every other day.!!!!
33x10.50 will fit no lift and little massaging of the pinch weld. 32x11.50 will fit as well.
95Runner
7
06-08-2002 01:02 AM
