Back spacing, rim size and tire size?
Old 09-11-2008, 11:33 PM
n2o302's Avatar
Im about to go on vacation and planning to put in my BJspacers and OME 901 coils in the rear. My question is I ran into a guy making me a deal on a set of welds they are 15x10 not exactly sure of the back spacing but what kind of back spacing should I be looking for and what size tire would be alright for a rim that size.
Old 09-11-2008, 11:42 PM
olharleyman's Avatar
I have 3.75bs on my 8"
Old 09-12-2008, 05:59 AM
4Crawler's Avatar
Stock is 4.75":
http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
The closer to that you get the better, 4.5" or so works well.
Old 09-12-2008, 07:23 AM
n2o302's Avatar
What type of tires do you recommend for that size of wheel I was originally going to go with 31x10.50 but checking the wheel site that might be to small of a tire for that rim. Didn't want to go to big this still is my DD everyday.
Old 09-12-2008, 07:35 AM
4Crawler's Avatar
Probably need a 12.50 wide tire for a 10" rim. Those will stick out pretty wide and increase the chance of rubbing on the front fender as well, at least in the taller sizes.
Old 09-12-2008, 08:39 AM
n2o302's Avatar
Even with bj spacers do you think it will rub.
Old 09-12-2008, 09:56 AM
4Crawler's Avatar
With 31s, likely not, but I said with taller tires. The wider the wheel and tire stick out from the fender, the wider the arc they sweep while turning. If that arch intersects the arch of the wheel well, you get rubbing.
Old 09-12-2008, 01:32 PM
Jay351's Avatar
If you are running bj spacers, you will need a wheel closer to 4" of backspacing, perhaps even 3.75 to be safe.
Old 09-12-2008, 02:00 PM
4Crawler's Avatar
Usually 4.5" or less w/ 31" tires:
http://www.4crawler.com/4x4/ForSale/...tml#DISCLAIMER
Old 09-12-2008, 02:57 PM
Jay351's Avatar
Whoops, I thought he was gonna run a wide 33" tire My bad!
Old 09-12-2008, 05:09 PM
n2o302's Avatar
I might run a 33" on these 15x10's not sure yet just wondering how a 31x10.5 would look like on a 10 inch rim from what I'm finding out the rim's came off of a tacoma that had a 4 inch total lift.
06-01-2021 01:51 PM
Whatever123
09-30-2015 12:12 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: Back spacing, rim size and tire size?
