33/12.50 on 3 inch lift.
Here's my '85 originally 3.5" lift and 33x9.50 tires:
- http://www.4crawler.com/4x4/4R_suspension.shtml#Epilog
Had to do a fair bit of work to get those tires to fit w/o rubbing including trimming fenders, I never had the front valence on the truck, 1" body lift ar the tires w/ no rubbing:plus I ended up moving the axle forward ~3/4" to finally cle
- http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseII
so i'm about to get an 85 toyota pickup 4x4 with the originol suspension on it and i want to put a rough country 3" lift and 31 inch tires on it. Does anyone have pics of a yota with this lift and tire size combo so i have an idea of what it would look like?
You probably will have to remove the valance under your bumper unless you get a little lift. Most of your rubbing is going to be on the rear of your tires turning or flexing. Mine did just turning into slightly sloped driveways. Even with shackles and a 3 inch lift I had rubbing. Fixed that one with a 2 inch body lift.
so more than likely i have to add another inch or so bodylift, what about just slapping a 1 1/4" spidertrax spacers in addition to the 2.5" lift? will that resolve the issue? perhaps goin' down in tire width size..
was wondering about a 98 sr5 if 33x12.5r18 would fit with 2 inch suspension lift? just bought some rockstars 18x9 with 0mm offset... any recommendations on tire size and brands? was thinking mtz's or the km2's
