Turn Signal and Tail Light Reconditioning and Restoration. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Staging Area For Tech Article Submissions
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-11-2009, 10:27 PM   #1 (permalink)
the 38 special's Avatar
Location: Formerly Greater Seattle Area - Currently South Austin, Texas
Talking Turn Signal and Tail Light Reconditioning and Restoration.
Turn and Tail Light Restoration.
Most certainly NOT a new idea, but its always nice when something is written just for us 'yota guys.
Okay I am going to start off by saying I did more of a "refurbish" than a full restoration of my tail lights and front turn signals because I randomly decided to spend the last two hours of daylight on this and only used products and tools that I had within my line of vision at the split second I decided to take on the task.
I honestly did not know that the bulb socket was an integral part of the reflector and that the lens would separate without the use of either an oven or heat gun until I started unscrewing things.
I decided half way through to pull my blackberry out of my pocket and take some pictures so sorry if this seems half-@$$ed, because it is.
Lets try to keep this quick and painless, it is my first tech writeup you know.
TOOLS:
Phillips screwdriver
Clutch Pick (optional- a pencil or paper clip could do the same thing here)
Supplies:
Faux Chrome in a can (Auto parts or hardware store)
Aluminum HVAC Tape (for those who cant work spray paint)
Simple Green (or any other suitable mild degreaser or basic bar soap even)
Dielectric silicone (Auto parts store)
Toothbrush (recommended)
Scrubby kitchen pad (under kitchen sink)
Q-tips (cotton swabs)
Cotton balls
Masking tape
Plastic Polish
Okay well now that we know all of what we need and may want, remove your taillights (4 screws each) and front turn signals (2 screws each).
1) First things first, if you have plants growing in your turn signals you may want to clean them out and devise or purchase some new seals. Wash old seals with a little bar soap.. the simple green seemed to make them overly soft and gave me a bit of a scare. We used to use simple green as tire compound to soften the rubber when I was 12 and I raced little gas RC cars - So I wouldn't use it on those rubber seals if you don't plan on replacing them.
2) Now I cleaned the reflectors (the part that SHOULD be shiny again when we are done) REALLY well. I goofed and didn't get any "before" shots, but who gives a crap how bad mine looked before I fixed them up. What matters is how bad yours are now, and how great mine are (and yours will be) after we are all done here! This is where the simple green is used.
3) Clean your electrical Connections!!
4) Put some dielectric silicone on a cotton swab and lube up your electrical connections in your light sockets. This will keep any paint from sticking to them (if you decide to submerge it in paint..?) and will help later down the road in preventing corrosion. Now jam a cotton ball in that socket. That is how we mask those. Now mask around the black trim portion of the reflector assembly with some masking tape. Do a good job here in the prep work and you wont regret it.
5) Heat up the paint a little so its room temperature and shake the crap out of it. I don't feel enthusiastic enough to explain the reasoning behind this right now.
6) Spray a VERY light mist first, and let it dry for a few minutes. The next one can be a bit thicker. All you want is for it to be for the most part smooth and shiny. It does not, I repeat it does NOT have to be perfect. This faux chrome paint is usually very thin and runs easily. The can I used has been in my garage for at least 10 years and in the last few years some major advancements in faux chrome have been made. If your lights don't turn out better than my 10-year old bumper in a can then you used dollar store stuff or glitter. Don't be cheap, your lights keep you safe at night, as well as others.
7) Now go clean your lenses and if you haven't, your gaskets while the paint dries.
8) If your like me and want to let things air dry for a good long while then go play with your lights and make sure you have good electrical connections, and that your paint dried nicely.
^this is what happens when the turn signal flashes.. not too bad.
Okay I am tired of writing step by step stuff.
Last step
9) I don't have to tell you how to put everything back together because you have the intelligence of a 2nd grader or higher.
9b) Polish. This is the polish I used.. Its okay. I recommend the $17.00 kit that you use a drill and buff the surface with.. much much better. I used a paper towel. You can see the difference with the product I used below - which is more for cleaning than actual polishing. The results could have been much worse, but at the same time could have been much much better. I'm happy and am not complaining.
Okay now the rest of the what now seem random pictures.
It is simple but wow does it make a difference. Later I will get started on the parking lamps (aka front corner markers).
__________________
1989 X-cab deluxe 3vze (3.0 V6) Auto, 3inch body lift, 33" rubber, 230k miles with another 200k to go. Stock 4:10's, Stock IFS.
^^AKA blank slate^^
I've still got a few tricks up my sleeve.
the 38 special is offline
Old 04-13-2009, 05:28 PM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
I tried editing the coding, but the pictures are WAY too big to be posting here.
Edit the pictures down to 1/2 the size, and we can post them up for you.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 04-13-2009, 06:08 PM   #3 (permalink)
I have almost no free time right now so it will have to wait a little bit.. i'll get to it. normally i would set them up as thumbnails and then you click them to open the full image.. that is how i will do it later most likely.. if i size them down then they will be too small to clearly see what the image is meant to display.
__________________
^^AKA blank slate^^
Tags
clean, compound, cover, light, lights, painting, polish, recondition, reconditioner, restoration, signal, signals, stock, tail, turn, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tail light: No brake light. Signal and parking work Skides General Electrical & Lighting Related Topics 1 04-02-2009 09:21 PM
parking light ,turn signal wiring question mean green General Vehicle Related Topics (Non Year Related) 2 07-13-2007 11:53 AM
Turn signal modification to corner light? terrytcl 95.5-2004 Tacomas & 96-2002 4Runners 2 08-30-2005 08:12 AM
Turn signal/Brake light wiring question pfdaxe 95.5-2004 Tacomas & 96-2002 4Runners 10 07-30-2004 01:05 PM
Turn signal and parking light bulbs 4x4Fink 95.5-2004 Tacomas & 96-2002 4Runners 6 08-20-2003 04:06 PM
2009 InternetBrands, Inc.
