Domestic Swaps Chevrolet, Ford, ect
My V8 swap 92 runner
Old 11-02-2010, 07:26 PM
Akilleez1's Avatar
sbc 350 th400 np208
Attached Thumbnails My V8 swap 92 runner-engine1.jpg   My V8 swap 92 runner-engine2.jpg
Old 11-02-2010, 07:44 PM
Akilleez1's Avatar
Originally Posted by Akilleez1
sbc 350 th400 np208
more pics
Old 11-12-2010, 05:49 PM
suckcreekoffroad's Avatar
what fan set up are you going to use to cool it with
Old 11-13-2010, 08:06 AM
Akilleez1's Avatar
Fans
I actually am using two pushing electric fans that were pulled from a geo metro or suzuki swift got them at the local wrecking yard They fit pefect right between the grille and core support so grille is still stock
Old 11-20-2010, 02:49 PM
Dras16's Avatar
How did you wire the motor. I have just about everything done except the wiring and i have no idea what I am doing when it comes to wiring.
Old 11-29-2010, 08:02 PM
Akilleez1's Avatar
wiring
So are you carb or injected? If carb it is very simple. Also are you using an HEI dizzy?
Old 11-29-2010, 08:11 PM
Dras16's Avatar
Carb. and yes HEI. I just dont know if i can run everything through the computer or if i have to bypass that. and if i can use the existing harness for the alternator and the distributor.
Old 11-30-2010, 04:19 AM
Akilleez1's Avatar
wiring
Okay so I left stock harness in place but I also used stock toy alt and toy powersteering pump just modded the brackets a little bit. As far as the HEI goes I think I ran a new wire to the hot via ignition switch I will look and verify that for you. Simply because its been 2 years and I dont remember lol. I did remove all the fuel injection mumbo jumbo because its not need. but leave the wiper connections etc.
Old 11-30-2010, 02:42 PM
Dras16's Avatar
ok Thanks, I am using the gm alternator and power steering. i just dont know about the alternator because on the stock harness it has 3 wires going into the plug and then another wire that bolts to the alternator... right? what about your starter relay? i read that it wont pull enough current to start a gm starter
Old 12-01-2010, 05:39 AM
Akilleez1's Avatar
If your set on using the gm alt. get a 1 wire hook up. as far as the starter goes I bolted main hot from battery to starter then ran a new wire from the ignition switch to the start switch terminal on the starter bypassing toyota harness all together. The 3 wires in the toyota alt harness is the reason I used the toy alt. Plus I have power everything in the runner and wanted the amps.
Old 12-03-2010, 06:56 PM
Dras16's Avatar
doesn't the gm alternator put out more amps? i already got rid of my toy alternator and can't afford a new one. thats why im using the gm. which wire did you connect to off the ignition switch?
Old 12-05-2010, 03:34 PM
Akilleez1's Avatar
wiring
Just depends on which GM alt you go with there is a wide range of amperage. As far as what wire to use from ignition switch you will need to use a volt meter to determin that...
Old 12-26-2010, 02:03 PM
Dras16's Avatar
Thanks for all the help. I was able to wire the starter, distributor, and oil pressure sending unit. Now all I need to do wire the alternator. Hopefully it will be running in a couple weeks! Also are you running a different brake booster and master cylinder? Oh and I used the original toyota starter wire from the ignition and it works just fine.
Old 01-18-2011, 12:54 AM
towyota's Avatar
Can you post more pictures of your build please? im trying to do the same. do you have ifs still or did you go sas? details of the build anything will be helpful thanks
Old 01-18-2011, 08:51 AM
Dras16's Avatar
what kind of pictures would you like. I did the sas. and the 350 swap. Are you doing all of this stuff too?
Old 01-18-2011, 09:51 AM
towyota's Avatar
any and all pictures from your swap
Old 01-20-2011, 08:26 PM
Akilleez1's Avatar
email me at akilleez1@gmail.com I will email you back some pics of my runner step by step of what I did. Hopefully it helps
Old 05-04-2011, 07:35 AM
Akilleez1's Avatar
ok update im building a new 350 its .030 over running edelbrock performer intake holley truck avenger vortec heads from a 98 burban now just trying to figure out the cam because the vortecs are somewhat limited on lift I want to get about 330 horse or more would be bonus I will have some new pics soon hopefully
Old 05-07-2011, 02:07 PM
Dras16's Avatar
Are you rebuilding your old motor or did you get a whole new motor? Sounds like its gonna have some good power. I dont know a whole lot about motors or what type of cam to use but someday would like to add more power to mine.
Old 05-10-2011, 06:58 PM
sshaner72's Avatar
v8 swap
i have a 86 toyota single cab 4x4 iam putting a small block chevy in and iam not sure what radator to run for a cooling system
Quick Reply: My V8 swap 92 runner
