My V8 swap 92 runner
2 Attachment(s)
sbc 350 th400 np208
3 Attachment(s)
Originally Posted by Akilleez1
(Post 51585883)
sbc 350 th400 np208
what fan set up are you going to use to cool it with
Fans
Originally Posted by suckcreekoffroad
(Post 51593054)
How did you wire the motor. I have just about everything done except the wiring and i have no idea what I am doing when it comes to wiring.
wiring
Originally Posted by Dras16
(Post 51598245)
:alert: |
Carb. and yes HEI. I just dont know if i can run everything through the computer or if i have to bypass that. and if i can use the existing harness for the alternator and the distributor.
wiring
(Post 51604874)
ok Thanks, I am using the gm alternator and power steering. i just dont know about the alternator because on the stock harness it has 3 wires going into the plug and then another wire that bolts to the alternator... right? what about your starter relay? i read that it wont pull enough current to start a gm starter
(Post 51605333)
doesn't the gm alternator put out more amps? i already got rid of my toy alternator and can't afford a new one. thats why im using the gm. which wire did you connect to off the ignition switch?
wiring
(Post 51607718)
Thanks for all the help. I was able to wire the starter, distributor, and oil pressure sending unit. Now all I need to do wire the alternator. Hopefully it will be running in a couple weeks! Also are you running a different brake booster and master cylinder? Oh and I used the original toyota starter wire from the ignition and it works just fine.
Can you post more pictures of your build please? im trying to do the same. do you have ifs still or did you go sas? details of the build anything will be helpful thanks
what kind of pictures would you like. I did the sas. and the 350 swap. Are you doing all of this stuff too?
any and all pictures from your swap
email me at akilleez1@gmail.com I will email you back some pics of my runner step by step of what I did. Hopefully it helps
ok update im building a new 350 its .030 over running edelbrock performer intake holley truck avenger vortec heads from a 98 burban now just trying to figure out the cam because the vortecs are somewhat limited on lift I want to get about 330 horse or more would be bonus I will have some new pics soon hopefully
Are you rebuilding your old motor or did you get a whole new motor? Sounds like its gonna have some good power. I dont know a whole lot about motors or what type of cam to use but someday would like to add more power to mine.
v8 swap
i have a 86 toyota single cab 4x4 iam putting a small block chevy in and iam not sure what radator to run for a cooling system
