302 wireing ishue
302 wireing ishue
I am puting a 302 in my 87 toyota did a strait axel swap with a ford high pinon 44 dfront end and matching rearend got the moter and trany set in and all mounts perdy much fabed up. then i got to thinking about the wiring. well my 302 came outa a mustang and the year it came out of has a...umm with my atv experience would be called a cdi box not sure in thise case but since i dont have any of the same plugins as the mustang did i am lost as to how to wire it up to my yota wireing harnes..... any one peraps know how todo this or have a diagram wich would be very helpfull i wona hury up and get this thing on the road...and in the mud....and sand!!!!!
I would replace the Distributor with a DUI unit. you can pick them up on Ebay cheep and then it only takes 1 keyed power wire. totally clean and runs great. good luck.
302 wire up
Personally if I was using a '77 302 I'd keep it simple. Stay with carb and use a
Mallory or Accel ignition. They work great and are very reliable.
Or put a Pertronix ignition in the stock dist. That is what I have in my 69 Stang. Get rid of that ignition box and get down to the minimum amount of wires as stated before, simple and easy to work on.
ToyoToler
08-08-2015 08:43 AM
