Diesel Swaps Diesel engines
2.2 3.4 perkins swap
Old 02-11-2013, 06:17 PM
Peterbilt17's Avatar
hello everyone,
im wondering if anyone can help me. my plan is to put a 2.2 or 3.4 turbo perkins engine into my 1990 toyota truck. i can mount the engine and rig it up to run.
The only problem im running into is a belhousing adapter to run to a manual transmission. any one have any ideas on how i can mount one of these engines (same belhousing bolt pattern) to a toyota tranny??
any help would be appreciated, thanks
Old 02-11-2013, 06:39 PM
niall's Avatar
make an adaptor, or all new bellhousing. Probably your only option.
Old 02-11-2013, 07:33 PM
totally a bro
Staff
vital22re's Avatar
If you're a 4 cyl now you need 3.0 transmission, t-case, drivelines, and crossmember. Also you'll need to move the engine mounts back about 4 inches to run the 3.4 otherwise if you're gonna go to another 4cyl you're fine.
If you are 3.0 now, go read the 3.4 swap section.
Old 02-12-2013, 03:31 PM
PowerstrokeJoe's Avatar
Just make your own adapter. I made mine for my OM617. It's not real hard just requires a little time and patience.
LosPatosDelSur
23
03-12-2021 03:08 AM
93toyoguy
08-02-2015 07:41 PM
Backcountry411
Diesel Swaps
07-29-2015 01:33 PM
94whiterunner
07-12-2015 07:15 PM
akaphilly
07-09-2015 02:34 PM
Quick Reply: 2.2 3.4 perkins swap
