1kz half cut
1kz half cut
I saw this the other day while perusing the website. Unfortunately I have already committed to rebuilding my 3.0 or it would be on like donkey kong. They're also right up the road from me, which just adds salt to the wounds.
http://nadauto.com/PartData.aspx?id=737
That ain't a half bad price, all things considered. Still going to need a couple pricey bits, like the fuel pump, fuel lines, and tank, unless the tank is the same as the gas tank.
You can still use your stock tank, you just have to convert the in tank pump to a pickup. I'm also pretty sure kz's have a lift pump and not an electric fuel pump. Could be wrong.
You use the stock tank and just either use the pickup that came with the half cut, or you mod your fuel pump yo be a sender by taking the pump out and putting in just a piece of pipe. The fuel lines from the V6 can be used. I am using them with mine. The fuel pump is the injection pump. There is a low pressure and high pressure side and the low is the lift pump from tank. On the fuel filter there is a primer if you run out of fuel for some reason. That price is what I paid for mine a few years back but I didn't get the cut I just got all of the part. Also that one has lower kms on it than mine did. Nice to have all the half cut spare parts too and the front lights and grill would have gotten swapped too into my pickup.
Jcrawl94
10
10-24-2015 04:34 PM
Peevedkitten
11
08-31-2015 06:57 PM
