SWAPPING problem 91 toy 3vze 3.0 into a 95 toy 4 runner 3vze 3.0 excange - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > All Other Toyota Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-16-2008, 07:13 PM   #1 (permalink)
HAWAII GUY's Avatar
ALOHA,I own a 1995 toyota 4runner with the 3vze 3.0 i went ahead and put in a 1991 toyota 3vze engine in it during the swap every thing was pretty much the same exept the ditributor cap and rotor i' m still using the whole harness and computer sys from 95 the only thing i rewired was the distibutor i barly got the thing to start and does not idle at all it seems lilke a air leak or missing almost i trying to go through every thing do ihave to use the computer sys from 91? I would greatly appriciate any help anyone can give me. MAHALO
HAWAII GUY is offline
Old 11-16-2008, 07:24 PM   #2 (permalink)
Elvota's Avatar
My guess is that you would want to use the ECM from the '91 on the '91 engine.
I'd double check all the wiring as well, make sure nothing changed between the years. The signals the sensors send and the pins they go to may fluctuate slightly with model years... but that's mostly a guess.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Old 11-16-2008, 07:32 PM   #3 (permalink)
HAWAII GUY's Avatar
if anyone else suggestions all are welcome MAHALO By the way im using the injectors and intake manifold from 91 engine they had all same clips my 95 throttle body fits right on 91 intake manifold
Old 12-01-2008, 01:51 PM   #4 (permalink)
FishOutOfWater's Avatar
some ideas
A couple simple items that you probably got already. these are some items I ran into when I swapped a 92 for a 93.
1. Check that all the throttle body vaccuum lines are connected or plugged. This could be your air leak.
2. When I set mine up I used the distributor that matched the engine I was putting in the 4runner, just to be sure everything worked out. The shafts are quite. Also, you have probably used a timing gun to check your timing, but before I used the gun, my distibutor was off a tooth. The engine would run/cough for 20 seconds then die. I spend a day looking for a massive vaccuum leak.
Good luck. Just so you are aware,your timing belt tensioner system will be a little different. Buy belts and water pumps for the appropriate year engine.
FishOutOfWater is offline
Tags
30, 3vz, 3vze, 4runner, 91, 95, computer, engine, harness, problems, swap, tensioner, toyota, tpi, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
my new toy.. 85 runner.. few questions matts65ss 84-85 Trucks & 4Runners 3 09-25-2008 08:02 AM
TH350 toy adapter & 4.7 toy case lizard lips The Classifieds GraveYard 9 02-06-2008 07:46 AM
3VZE Idle circuit experts (Toy Master Tech ?) nrgetic99 95.5-2004 Tacomas & 96-2002 4Runners 4 10-17-2005 08:35 PM
Nice Rims for Toy-Toy wheelerz 95.5-2004 Tacomas & 96-2002 4Runners 4 04-14-2005 11:37 AM
Swapping the 3.0 Toy w/305 TPI Chevy jahMcS 95.5-2004 Tacomas & 96-2002 4Runners 1 06-11-2004 07:07 PM
2009 InternetBrands, Inc.
