| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
new generation swap options (1GR-FE, 2GR-FE, 2TR-FE)
#2 (permalink) |
If you were ok with putting in an auto Id say go with the 1uz instead.Not very much info on the other swaps you are talking about.
Just recently finished mine and what a difference.
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ |
#3 (permalink) |
yeah, i've seen the 1UZ info (including your thread, thank you for that btw, wish more people took the time to document swaps like you did) but i'm strictly opposed to autos.
alfio |
#4 (permalink) | ||
I'd drive a Rav4 before considering it. Those engines don't seem to make much low rpm power unfortunately, and thats on a lighter vehicle.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#5 (permalink) |
what ya tryin to swap these into? 4runner or truck?
__________________
new to me 86' toy on 35" procomp mud terrains, with a 4" lift and 3" body and palm fron camo for now... 04' Dodge 2500 4x4 QC hemi leveled, home made CAI and flowmaster exhaust |
#6 (permalink) | |
Quote:
edit: after a quick search i found this: http://www.toymods.net/forums/showthread.php?t=43884 2GR-FE into an MR2. his dyno shows some nice power. alfio Last edited by alfio; 09-11-2009 at 03:14 PM. |
#7 (permalink) |
#8 (permalink) | |
Why would you want the 2GR-FE? It's only high end power. Your truck NEEDS low end power. That link is for an MR2, they don't need low end torque as much as a truck. The 2TR is used in the newer Tacoma but why swap in a 4 banger when you could swap in a 5VZ or a 1GR or heck even a 2UZ.
__________________
96' 4Runner SR5 Bone Stock, 100K as of 7-9-09 Quote:
#9 (permalink) | |
Quote:
alfio |
#10 (permalink) |
The 2gr is a front wheel drive engine. Not sure how that would affect a rwd swap.
Does anyone know what trannys will bolt up to any of these engines?
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#11 (permalink) |
why not the 3rz the 2.7 4 banger from the taco's ? pretty much the same thing as the 3.0 performance wise better gas mileage and pretty much bolt up in a 22re equiped truck.
__________________
92 toyota truck 3.4 5spd 4.56 gears magna flow cat and muffler2 1/4 piping isr mod to intake 1.5 bjsfront add a leafs and 2inch lift shackles rear rancho shocks all around sitting on 265/75/r16 nitto terra grapplers |
#12 (permalink) | |
Quote:
the 2RT-FE is interesting because it appears (i say appears because i don't have the key piece of data yet) to be much lighter than the 2RZ or the 3RZ. it is all aluminum and has a ton of plastics incorporated to save weight (and cost of course). it also has VVT-i which is better at managing power and fuel consumption than previous generation motors. check out the chatter on marlin: http://board.marlincrawler.com/index.php?topic=48380.30 this would appear to be the swap of the future for those of us hunting for manageable power without a ton of weight. alfio |
#13 (permalink) |
just remember the 2rt is drive by wire, so u will need all of the wiring with the electronic gas pedal too. it sounds like a pain to mee, but i would like to see someone swap one of these into an older truck
__________________
i drive by brail. Rock Solid Motorsports http://www.rocksolidmotorsports.net/ http://www.lunatic4x4.org/forums/forumdisplay.php?f=45 |
#14 (permalink) |
i know, drive by wire sounds like a total PIA but i am looking for a project to learn more about electronic components. still, i'm a ways from taking this on, just playing with the possibilities at the moment.
i would have to a) verify the weight differential and b) find a way to bolt it up to my r150F trans before i considered doing it. alfio |
#15 (permalink) |
the 2rt uses an r series transmission stock, so it will bolt right up
__________________
| Tags |
| 1grfe, 22re, 27, 2gr, 2grfe, 2tr, 2trfe, 4runner, dyno, engine, performance, swap, swaps, toyota, weight |
