22rte and w58 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > All Other Toyota Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-25-2009, 09:23 PM   #1 (permalink)
22rte and w58
Ok, I know this is probably a very easy question, but I can't find any definative information through a search. I have a 22re with a 5spd, I just bought a 22ret with an auto.
I want to put the 22ret into my 5spd truck. Now, I have found that the 22ret came with a r151 trans (23 spline), and my 22re trans is a w58 (or is it a w56??? I am not sure, whatever was stock for 1986) (21 spline).
Can I just use my 22re flywheel, clutch, disk, and w58 (or w56?) with the 22rte? I know it won't be as strong, but thats not really a concern. If this doesn't work, how about a 22rte flywheel, p-plate, and 22re disk?
As for the auto trans, it is for sale if anyone is interested (located in Winnipeg, or Calgary).
__________________
1986 SR5 4x4 Xtra cab Turbo
Sushi is offline
Old 07-26-2009, 09:52 PM   #2 (permalink)
Wait... I think I figured it out. It's the output shaft on the r151 that is a different spine count. So, this means that using a regular w series 5spd with a 22rte I can use either the stock 22re clutch flywheel setup, or the larger 22rte setup.
Is this correct?? Anyone can confirm it? I need to buy some parts tomorow or Tuesday.
__________________
Sushi is offline
Old 09-02-2009, 05:33 PM   #3 (permalink)
i am trying to find that same info, cause i have a 22re engine and was wondering if i can use a 22rte flywheel, pressure plate and disk with the stock w series tranny will it bolt right in with no problems or would i have to get a turbo bell houseing
smooth87sr5 is offline
Old 09-02-2009, 07:02 PM   #4 (permalink)
I managed to mate my 22rte to the w series transmission with no trouble at all. I used the 22re flywheel and clutch set. From what I gathered, and what I saw within the transmission you should be able to interchange any of these parts with no modification. If you want more information go to www.22rte-trucks.com , there is alot of good information on that site.
__________________
Sushi is offline
Old 09-02-2009, 08:46 PM   #5 (permalink)
JamesD's Avatar
Everything you have is a bolt on deal. No modifications. The only thing you need is a driveshaft out of a 4 cyl truck which are easy to find.
James
__________________
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569
Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/
JamesD is offline
Old 09-02-2009, 09:38 PM   #6 (permalink)
85excab's Avatar
if u want to keep the turbo flywheel and pressure plate, get a clutch disc for a 92.5-94 22re, its the same size as the 22rte disc with 21 splines.
__________________
i drive by brail.
Rock Solid Motorsports
http://www.rocksolidmotorsports.net/
http://www.lunatic4x4.org/forums/forumdisplay.php?f=45
85excab is offline
Tags
1986, 22ret, 22rte, 23, cab, clutch, forum, gmtew58, output, spline, sr5, tranny, w56, w58, xtra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
